Maximum boost with BMW Performance Power Kit - a bit of a surprise ?
10-17-2010, 09:56 AM | #1 |
Rep 3,262
Since installing the Rixter vent gauge I have tried to get a maximum boost reading and today I have managed to get a rather high 11psi (gauge was calibrated). Some people said that the stock 8.8psi is increased by about 1psi, but 11psi is kind of cool. The 297whp I got on the dyno can be fully explained with this kind of boost.
I'm curious if someone measured more than 8.8psi on a completely stock car ? I am at 100-150m above sea level.
10-17-2010, 10:00 AM | #2 | |
Rep 18,218
Of course I was at 5200 Feet elevation
10-17-2010, 11:14 AM | #4 |
Rep 4,764
That is correct. I have my tune set at max PSI of 17 with 93 octane and meth. If I run through one gear with no DTC intervention then I see a peak recall of 16.9-17.1 PSI on Rick's boost gauge. If I slip the wheels to get DTC intervention, and/or shift gears, I will see spikes up to about 1 PSI higher. The engine actually does not see that spike, but gets recorded as a spike in the manifold pressure, and reflected on the electronic gauge peak recall.
10-17-2010, 12:23 PM | #5 |
Modder Raider
759
Rep 8,633
Drives: M3
Hs it been hot lately in your neck of the woods?
I'm curious if the car is running higher boost to compensate for the heat. Or, I believe that the others are correct with the boost spiking between gear shifts.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
10-17-2010, 12:37 PM | #6 |
Rep 7,377
peak recall on boost spikes when shifting
10-17-2010, 01:39 PM | #7 |
Rep 3,262
Probably a spike, the temperature was in fact quite low at 8-10 degrees Celsius.
