lets talk about turbo lag
10-20-2010, 12:10 AM | #1 |
Rep 571
Ok so i have been reading about turbo lag and im not sure if i have it
I have a 07 335i with jb3 2.0 and a boost gauge At 2k rpm in 4th gear i am making about 1lb boost crusing. If i floor the car, it the boost jumps instanly to 5 psi and by 2500 rpm i and at 10 psi and then the car takes off like a raped date and tops out at about 14.5 psi Is that normal or am i having lag and boost should build lower in the RPMs? |
10-20-2010, 03:04 PM | #3 |
3442
Rep 79,211
What kind of gauge are you using to read boost....
What other modifications are done to the car. My boost jump instantly to 17 PSI from almost any gear any RPM. You should be able to build boost at low RPM on this car. |
10-20-2010, 04:35 PM | #4 |
Rep 571
I am stock with a INATKE and JB3 on map 5
Like i said i can start building boost at low RPM but it does not start to come alive until about 3k rpm. When rolling arond in 4th gear at say 40 MPH, my digital boost gauge reads like 1 psi and if i floor it the boost jumps to about 5 and slowly accelerates and then at about 2500 the boost is up around 14psi and at 3k the car starts to pull super hard But from 1000 rpm to close to 3000 rpm the car is not quick |
10-20-2010, 05:03 PM | #5 | |
3442
Rep 79,211
This car doesnt really hit its sweet spot till the 4500 RPM range. |
10-20-2010, 05:10 PM | #7 |
Rep 5,751
10-20-2010, 05:16 PM | #8 |
Rep 571
Ok lets try this,
How many RPM are you guys at before you see over 10psi boost? Maybe that will help my brian understand this better and what RPM are you seeing peak full boost |
10-20-2010, 06:36 PM | #9 |
Rep 549
I'd say turbo lag is from the time you stomp the throttle until the time the car get's going.
In a NA car, it just starts going at once. Sure, NA cars also have their sweet spots, but they do react in almost any RPM range. Newer turbo cars have no big turbo lag to speak of. Go drive an evo or sti from 2007 at 2000 rpm in 4th, stomp the throttle and you'll know what turbo lag is for sure. If you have turbos you have turbo lag, that's sort of hard to get around. If you have a 335, you don't have a lot of it though. |
10-20-2010, 06:45 PM | #10 |
Rep 3,396
Q: How does that "lag" feel, anyway? How can I reproduce it?
A: Go in 4th gear (or M4 with steptronic) at ~1500 RPM, then depress throttle halfway. If you feel a second rush of acceleration only when RPM reaches 3000 after ~0.5 seconds, you are experiencing lag, since full torque is supposed to be present from ~1400 RPM already. |
10-20-2010, 07:04 PM | #11 |
Rep 571
If full torque is made at 1400rpm, what should the boost be at full torque at 1400 rpm? Cause at 1400 RPM my car is a snail and they 3000 comes around and you better hold on
10-20-2010, 11:33 PM | #13 |
Rep 134
10-21-2010, 12:20 AM | #15 |
Rep 252
turbo lag is to do with the *time* delay from when you stomp on the pedal to when the max torque available at the current rpm hits. It does not mean you can't acheive a certain amount of boost at an rpm. You may be getting confused because during this time you'll be accelerating and you're no longer at the same rpm anymore so you think that XXpsi at 2000rpm is unachievable but that's because by the time the lag period is over you're no longer at 2000rpm.
Turbo lag is due to the interactive nature of the turbo and engine. If the engine isn't producing enough exhaust to turn the turbine quickly then you can't achieve high boost until it does produce enough exhaust gas pressure. It just happens more at low rpm because there is generally "less" exhaust |
10-21-2010, 12:56 AM | #16 |
Rep 1,665
Your car has turbo lag, but ALL turbocharged cars have this. Hitting 10 psi of boost at 2500 rpm is fine. Nothing's wrong w/ your car.
The 335 has significantly less turbo lag than other turbocharged cars in the past, but it still has it. I would describe it more like a soft throttle response. On a NA car, when you hit the gas, there's instant acceleration. In the 335, when you hit the gas, it feels slightly delayed... like the throttle is a bit soft in responding. That's turbo lag. Still, much better than in the past where you'd have to count 1-1000, 2-1000, 3- BAM car slingshots ahead like crazy. |
