10-21-2010, 11:29 AM | #1 |
Rep 827
Air Compressor
I finally finished cleaning out and re-organizing my garage and am looking for a decent 30-60 gallon air compressor. Does anyone have some brand recommendations? Tools I'm looking at for now are below. Brand of tools would also be appreciated. I asked my brother and the first word(s) out of his mouth was "Snap-on!"
- Impact gun - 1/2 right angle socket - Die grinder - Polisher/Buffer - Gravity-fed spray gun (already have this one with a smaller compressor) So far I'm eying an Ingersol-Rand and already have a 230V outlet set up. Link
Down for Maintenance
10-21-2010, 01:45 PM | #3 |
Rep 2,874
Whatever you do, don't buy a reed style compressor. Get a piston style. Reeds are so loud you cant even stand in the same room when they're on. Pistons are way more money, but worth every penny.
10-21-2010, 02:04 PM | #4 |
Rep 827
I've been reading that 110V are louder than 220V. More volt, less amp, less work, less noise I guess. As far as reed vs piston, I need to check what that IR compressor is. Reviews I've read so far is that it is on the quiet side (for a compressor), but their word "quiet" might be subjective.
10-21-2010, 02:14 PM | #5 |
Rep 2,874
Trust me, reed compressors are "Holy fucking hell" loud. You don't want one. IR usually makes piston, but expect to pay over 300 bucks for one. Look here for info.
http://www.aircompressorsdirect.com/ |
10-21-2010, 03:08 PM | #6 | |
Rep 3,330
F80 ///M3 6MT Avus Blue ZCP |
10-21-2010, 03:14 PM | #7 | |
Mad tyte EuR0 style boooi <--- Joke
222
Rep 2,472
10-21-2010, 10:17 PM | #10 |
Rep 827
What is the minimum clearance the stationary compressors need around them? I have 30" from the wall to the door-line where the vehicles would come in.
I just saw one review that said a minimum of 18" was required so....damn.
10-28-2010, 08:11 PM | #12 |
Rep 827
I'm looking at this one from Campbell Hausfeld. Dual piston, belt driven, 240 V.
http://www.northerntool.com/shop/too...7421_200377421 I would most likely buy it from my local sears since they have been running a special, buy any compressor, 25% off air tools. Opinions?
10-28-2010, 10:01 PM | #13 |
Rep 358
Oil-less compressors are usually ridiculously loud and have a smaller service life vs the oiled version, but they're cheaper. Dual stage will put out more CFM than a single stage compressor, but they usually require 208VAC input.
Get a compressor that will be enough CFM for the tools you're trying to run and if you're planning on using it a lot, I'd recommend an oiled version.. The rest really depends on your budget. Name brand also makes a difference imo. Ingersol Rand which was mentioned above is like the Lexus (I say Lexus because less issues than BMW ) of compressors and as such will be a higher cost.
2006 e90 330i | Black/Terra | 6MT | ZSP | ZPP | ZCW
10-28-2010, 10:12 PM | #14 | |
Rep 827
Wondering if anyone on here has purchased one of these units before. So far the online reviews of this unit are that it is the best all-round portable unit without breaking the bank.
11-15-2010, 09:36 AM | #15 |
Rep 358
Campbell Hausfield is another awesome brand, up there with IR.. over 10CFM @ 90PSI huh? Planning on running a shop?
11-15-2010, 09:59 AM | #16 | |
Rep 827
I'd rather make a larger investment at the start then down the road, get a new tool and find out I'm not getting the full potential of it because of my compressor.
11-15-2010, 11:17 AM | #17 |
Rep 8,688
Drives: 06 330i
11-15-2010, 11:26 AM | #18 |
Rep 827
Which one and how much clearance do you have around it?
11-15-2010, 11:29 AM | #19 |
Rep 8,688
Drives: 06 330i
IR 3077-0010
lots of space =D |
11-15-2010, 11:38 AM | #20 |
Rep 827
That is the one I mentioned in my earlier post and that is also why I probably can't fit it in my garage. IR vs CH is an 8CFM difference at 90PSI for $300 (Northern tools). I would go for IR to negate any potential of having to upgrade down the road, but I think for my weekend warrior workshop, the CH will (hopefully) do just fine.
11-15-2010, 11:41 AM | #21 | |
Rep 8,688
Drives: 06 330i
