E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Lackluster performance
Reply
      10-31-2010, 08:25 AM   #1
Aogden
Drives: 335i Cabrio
Hi everyone,
I have a 2009 335i cabrio which I purchased new about three months ago.
I started with the DCI and JB3 PnP and when that didn't give me the power I wanted I went ahead and put a HPF intercooler in and downpipes from BMS I think it was.
Anyhow, I have tried every map on the JB3 and the difference is not considerably noticeable. When I go WOT it seems like something is holding it back and I'm not sure what it could be.
I have the Diagnostic cable, but haven't spent much time investigating it's features other than to check for codes after the installs.
Any suggestions?
Tony
      10-31-2010, 08:41 AM   #2
tscdennab
Drives: BMW 335i
2008 BMW  [6.24]
Go to a dyno...
      10-31-2010, 08:43 AM   #3
Aogden
Drives: 335i Cabrio
I've been considering that but I haven't yet.
      10-31-2010, 08:43 AM   #4
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
just leave it on map 7 for a week and see how the car feels. if you dont get codes or limps means the car is fine. You feel a huge difference from map 0 to map 7 . are you sure that you are actually on the right map?
      10-31-2010, 08:53 AM   #5
Aogden
Drives: 335i Cabrio
I feel a difference from 0 to 7 but it is by no means huge.
Doing the downpipes I had a friend actually working on them while I did the Short shift kit. Any chance he mislabelled the O2 sensors? Would it even run?
When I go WOT there is a fair amount of lag - at least a one thousand one - before I feel boost -
Would it make a difference to turn off the traction control?
Thanks for the quick responses.
Tony
      10-31-2010, 08:54 AM   #6
MKE_M3
MKE_M3's Avatar
Drives: 2011 e90 M3
with your mods the car should be severely traction limited in the first two (maybe three?) gears. I don't want to sound condisending, but have you tried turning the traction control all the way off? It could be the traction control cutting throttle/applying brakes. I've heard other forum members complain about power delivery and had this been the problem.
      10-31-2010, 08:56 AM   #7
Topless///M
Drives: e92 335i 6mt, 94 probe gt
Get a boost gauge (or log boost) to make sure you're hitting targeted boost and make sure you have no boost leaks from IC install.
Make sure the DCI is installed correctly. The black couplers should only be in a 1/2" and no more than a inch into cones or you'll be doing more harm than good. Press the other ends into the accordion type plastic intake tubes as far as possible so cones don't hit each other. That's the only thing I can think of that could be choking the engine at higher revs especially at WOT.
Don't run any higher than Map 7 without higher than 93 octane either. To confirm you're making the power. Dyno it with baseline (stock map) and/or run it in the 1/4. You could try running Meth with a failsafe system next if you're still not happy with the power.
      10-31-2010, 08:57 AM   #8
Aogden
Drives: 335i Cabrio
Jdemetry,
Not offended at all, I will go give it a try.
Back in a few,
      10-31-2010, 08:59 AM   #9
Iwantm3
Drives: 335i M sport
I don't think your jb3 works or something might be wrong with the mods you have on map7 the car should be MUCH quicker and I mean 7 8 cars difference
      10-31-2010, 09:10 AM   #10
Dr_Dirt
Dr_Dirt's Avatar
Drives: E90 335i 6AT
Is the yellow triangle lighting up?
      10-31-2010, 09:30 AM   #11
Aogden
Drives: 335i Cabrio
Sorry gang for wasting your time, I just tried with traction control off and wheels break loose easily at 30 to 40mph in second gear with WOT. I never hit WOT in first, about 2/3 before wheel spin.
And can definately tell difference between Map 0 and 7 now, but no noticeable difference between 6 and 7
Tony
      10-31-2010, 09:38 AM   #12
scrufy
Zoom Zoom This
scrufy's Avatar
Drives: The Short Bus
Tony
I had a similar thing when I first tuned mine. Didn't notice a lot with TC on but take it off and weeeeeeeeee!!!
glad you got it sorted out.
      10-31-2010, 10:44 AM   #13
MKE_M3
MKE_M3's Avatar
Drives: 2011 e90 M3
no worries. If you're not used to the electronic nannies you may think there is something wrong with car because of them. I am getting an LSD installed soon and have heard it really cuts down on the interference of the DTC/DSC.
Reply
e90post
