Difference between different LSDs
11-01-2010, 03:27 PM | #1 |
Mad Linux Guru On The Loose
1130
Rep 5,400
Ok folks,
I searched and I could not find any decent comparison between the different LSDs available for our cars. Here is the list: 1. Quaife - approx $1300 2. Wavetrack - approx $1200 3. Dinan ($2599 - $1400 core exchange) - approx $1200 I know that the Dinan is a torsen type differential. How do these diffs stack up?
11-01-2010, 03:31 PM | #2 |
Rep 1,190
All 3 are torsen style diffs. The Main difference is that the wavetrac can operate when there is 1 wheel completely in the air(under no load).
I think your understanding of the price of the dinan diff is off a little. The Diff itself is 2500 and then 1400 added on top. The real question you should be asking yourself is if you have a welded ring gear or not. That's the big wallet buster.
2011 VW GTI 4dr-6mt-Sunroof-Nav-Xenons
OLD: 08 335i AW/CR/Poplar 6mt-ZSP-ZPP-ZCW-iPod-iDrive-PDC-Style 230s w/FK 452-Dinan LSD |
11-01-2010, 03:38 PM | #3 |
Rep 1,467
Yes, all are torsen-style (torque-sensing, aka helical).
Price for dealing with welded crown has gone down. Not as bad as it used to be. Although, the diff itself is just the beginning. You still have to get a carrier, and do the work of swapping the internals. Or you can buy a complete carrier, but it's more costly. -scheherazade |
11-01-2010, 03:43 PM | #4 |
1130
Rep 5,400
Ouch! I did not see that one.. Yeah, that Dinan unit is indeed expensive...
11-01-2010, 03:48 PM | #5 | |
Rep 1,190
Was it expensive? Yes Would I do it again? YOU BETTER BELIEVE I WOULD. Way too much fun with a LSD.
11-01-2010, 03:54 PM | #6 |
1130
Rep 5,400
Wait wait... I am bit confused here...
I do believe that I have a welded crown gear in my Oct 2007 production. When you order your Dinan LSD, what is involved into installing it on cars with welded crown gear vs cars without?
11-01-2010, 04:16 PM | #7 |
Rep 1,467
Welded :
Crown gear is welded to the stock differential. You need to : 1) Have the crown gear machined off of your stock differntial, and then prepared (drilled). Attach the machined crown gear to your new LSD, and install the LSD into your carrier. 2) Buy a new crown gear and attach it to your new LSD (Put the old crown gear + lsd on a shelf. Let them gather dust.). Install the LSD into your carrier. 3) Buy a complete carrier, with LSD already installed, all gears included, all assembled and ready to go. -scheherazade |
11-01-2010, 04:34 PM | #8 |
1130
Rep 5,400
OK that makes sense.
Does the Dinan LSD come assembled with complete carrier? If so, then this might be a better to buy that and have it installed rather than disassembling the diff innards.
11-01-2010, 05:11 PM | #9 | |
Rep 1,467
Not to come off too opportunistic... I still haven't sold my rear carrier (Wavetrac LSD 3.08 MT). A little under 10k miles on the clock. If you're ever in the D.C. area... -scheherazade |
11-01-2010, 05:18 PM | #10 |
Rep 2,084
The Dinan LSD comes assembled in a replacement differential. You swap the diffs, send your old one back to Dinan, and Dinan refunds the $1400 deposit. At least that's how it works if your dff is welded. I don't know if Dinan has other options.
In the Wavetrac group buy I am participating in, it is $1587 for the Wavetrac + assembled diff and $800 for the deposit - great price. |
11-01-2010, 05:35 PM | #11 |
1130
Rep 5,400
You mean they send me the complete final drive unit (the pumpkin) and all I have to do is mount it on the car and attach the half hafts and the drive shaft, correct?
If that's the case then this could be a good option for me...
11-01-2010, 05:56 PM | #12 |
Rep 2,084
Yes. But I believe you can get the same deal from HPA Shop for a Quaife or Wavetrac pre-assembled in a final drive unit that you'd swap for your old one.
11-01-2010, 06:21 PM | #13 | |
Rep 4,764
Prices have changed since I did mine earlier in the year, but definitely compare. |
11-01-2010, 06:54 PM | #14 | |
Rep 1,190
When I calculated final cost for everything, Dinan came out to be a little more expensive than Wavetrac and cheaper than Quaife. On top of that, I got a discount from the dinan rep(I just asked and he gave it) and a loaner car for when my dealer did the install.
11-01-2010, 10:23 PM | #16 |
1130
Rep 5,400
Great, thanks for the info guys. I really don't trust the local shops to mess with my final drive unit. I'd rather have an already assembled, re-shimmed unite that I can just chuck in and out of my car in 1 hour.
I'll definitely inquire abut quaife final drive. I am not very impressed by the technology behind wavetrack and even though we are seeing some good initial reviews from forum members, wavetrack are still newcomers to this game. Only time will tell if their units will last as long as the established makers like Quaife.
11-02-2010, 04:51 AM | #17 |
Rep 5,175
Guys keep in mind there are more design differences between the Quaife and Wavetrac as well. The Quaife uses a scrolled output shaft just like the stock open diff, where the Wavetrac does not. It is well known that scrolled output shafts are to prevent seizure and it is a big difference between the Wavetrac and Quaife imo.
11-02-2010, 05:53 AM | #18 |
Rep 7,377
The Dinan is a QUAIFE by the way...... just overpriced.
