DIY for swapping tires?
11-02-2010, 04:57 PM | #1 |
Dreamer
34
Rep 837
I did some research, and checked the DIY forum, but I couldn't find the DIY link for swapping summer wheels/tires for winters on an E90.
Anyone have one with pics? Yes I know swapping tires to many people is easy. I'm a bit paranoid and a newbie so I want to do it right!!! thanks P.S. No sarcastic comments please. I know I can just get it done at a local shop but I am interested in learning and doing it myself. thanks. ***OKAY**** FOUND DIY LINK. thanks Last edited by BavFan_08; 11-02-2010 at 06:20 PM.. |
11-02-2010, 06:20 PM | #4 |
Dreamer
34
Rep 837
11-02-2010, 06:24 PM | #5 |
Rep 202
do u want to take off the whole set(wheel+tire)? or taking the rubber off the wheel? i believe thats the question first...
if u want to take the rubber off the wheel, then u need to find a shop to do it. Yet, if u just want to switch the current set(4X wheel+tire) into another set (a winter set i suppose?) then u just need a jack and a wrench will do the work. hope that helps... |
11-02-2010, 08:18 PM | #6 |
Rep 2,266
What you're looking to do is to swap wheels(with already mounted tires). In which you would just need to get an torque wrench/jack/maybe impact wrench if you want ease. But anyways, if you're uncomfortable doing it once, ask a friend or watch a shop do it once or twice. it'll come easy after.
Now, as for mounting TIRES on wheels without machine..it's possible. Watch and be amazed! http://www.youtube.com/watch?v=_M0GNLvPmAg
Cheers
Ben |
11-03-2010, 02:24 PM | #7 | |
Rep 443
You shouldn't need to jack up at the corners like that. If all you're doing is swapping tires, you should: - jack up the whole front end from the front crossmember under the engine. - jack up the whole rear end from under the diff casing Only two lifts, 4 tires changed. Done. Must quicker than doing 4 independant corner lifts. The car is designed to be lifted at those points (front and rear), so why wouldn't you? The 4 corner points are primarily for jack stands and 4-point lifts. |
11-03-2010, 06:23 PM | #8 | |
Dreamer
34
Rep 837
Thanks guys! Yes I am just looking to swap summers for winters - just swapping wheels with already mounted tires! Thanks for the advice....so If I want to do lifts, what kind of jack would I need? Im guessing a 3 tonne jack wouldnt be enough? |
11-03-2010, 10:07 PM | #9 |
Rep 680
If you have multiple jacks and/or jack stands, then the method above will work. Most of us only use one jack, one corner at a time.
There is a jack point behind the front wheels and in front of the rear wheels. You can check your manual and then look under the car for them. I use a floor jack, but any jack will do. Just be sure the jack will fit under your car. Loosten the lug nuts a little, jack it up, loosten them the rest of the way, take the wheel off. Put the new one on, line up the holes,tighted the lug nuts. Best is to use a torque wrench. I think it is 88 lb, but check the manual. Or use a tire iron and make sure not to reef on it too hard. First wheel will probably take 25-30 minutes, but the 4th you'll have it down to 5-10 minutes. |
11-04-2010, 06:20 AM | #10 |
Rep 125
There is lots of good current info here......
http://www.e90post.com/forums/showthread.php?t=447644 about jacks and other tools you may want to change your wheels. |
11-05-2010, 05:32 PM | #11 | |
Rep 443
What I described only involved two lifts, but not done simultaneously. Lift front end, swap front two tires, let down. Lift rear end, swap rear two tires, let down. Simple. |
11-05-2010, 06:54 PM | #12 |
Rep 206
any trick to taking the wheel lock off when its too tightly screwed in?
I was able to swap 3 tires out, no problem... The last tire, the wheel lock nut is too tight....I snapped the 1st wheel lock.. went to buy another one... snap again.. argh.. quit for the day after another trip to the dealer and cleaned their stock of wheel locks.. after 3 broken wheel locks....how can I unscrew the nut without snapping the wheel lock? my last option is take it back to the dealer.. |
11-06-2010, 12:55 AM | #13 | |
Dreamer
34
Rep 837
Hmm...were you using an impact wrench? or a breaker bar with an extension? |
11-06-2010, 12:45 PM | #14 |
Rep 206
11-06-2010, 03:54 PM | #15 | |
chris
280
Rep 12,144
thats not going to work on my car. way too low to get to the middle jack point. i do the same procedure as what the guy in the DIY did. basically jack 4 points one at a time.
Current: 2013 F10 M5 & 2016 Mini JCW 2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone) |
11-06-2010, 04:42 PM | #16 | |
78
Rep 1,208
The wheel lock shouldn't break. Just use the metal pipe method and apply pressure slowly. |
11-08-2010, 10:22 AM | #17 | |
Rep 443
A torque wrench is a precision instrument designed to apply final torque at a specific value when you're putting the lugs on, not taking them off. As others have mentioned get yourself a decent breaker bar. |
11-08-2010, 02:55 PM | #18 |
Rep 896
Drives: 2021 X5
That summs it up. I use a torque wrench and have a hydraulic lift/jack. Easiest thing to do.
2018 540d xDrive Carbon Black Metallic on Cognac leather. Spec'd out to the max
2017 Mercedes C43 AMG Coupe. Black on black |
11-08-2010, 03:35 PM | #19 | |
Rep 206
Is this the breaker bar you're talking about? http://www.canadiantire.ca/AST/brows....jsp?locale=en |
11-08-2010, 05:15 PM | #20 | |
Rep 443
11-08-2010, 05:27 PM | #21 |
Rep 2,312
Just did it in my garage
Few tips: 1. Make sure you use a torque wrench (90 ft*lbs +- 5 of torque); do NOT loosen ur lugs with torque wrench -- you will messs up the calibration 2. obviously have a small $10 air compressor to refinflate winters tires when finished 3. check your work twice - make sure you did tighten every bolt 4. jacking the car up is no big deal - use the jack mounts, see manual for location. |
11-08-2010, 07:10 PM | #22 |
Rep 4,703
DIY it, its very easy to do.
If your out in the east end (Whitby) I can help you with it as I have all the necessary hardware and tools. Sometimes you just need someone to show you once just to get the confidence to do it yourself. |
