How-To: Procede v4 PnP harness update (optional)
11-03-2010, 07:21 PM | #1 |
1750
Rep 17,960
Drives: A Lot
Hi guys,
Starting next week, we are going to make a small update to the v4 PnP harness. This update physically eliminates the o2 modifier feature that most people no longer use. This is because most people: 1) are running with factory catalytic converters OR 2) are using CANclear to suppress cat codes in their off-road use only race cars Those racers who are using the o2 modifier feature to suppress cat codes shouldn't do this update. Or, better yet, they should should AND get their DME software updated to someone more recent than circa-2007 so that CANclear works The advantage of this update it two-fold: 1) It opens up 1 analog input and 1 analog output channel. Which we will use at a later date (not saying for what). 2) It removes the o2 sensor wiring in the harness so that the o2 sensor signal no longer has to go into the Procede, get converted to digital, then recreated into analog, then split into two and then sent to the DME. Even when the o2 modifier is turned off in the user software (o2 modifier=100%), there is some some signal processing which is no longer needed. And when we no longer need to process a signal, we should remove it from the circuit. Here's How: Step 1 This can be done with the Procede installed in the car. But for the sake of clarity, we did the work on a table. Locate the Patch harness that has all the fuel control functionality. It is the one with the small black subconnector. If you v4 harness is reasonably new, it will have yellow wires. Look for the pin with the missing wire: Step 2 Remove the following wires: There will be two wires that you remove. One will have a single male end. And the other will split off into two female ends. Make sure the wires you remove look like what you see above. Step 3 Next extract two unused patch wires from another subconnector. Your v4 harness has many patch wires that aren't used. You can tell that it's unused by looking at the factory connector that it mates with. If a pin on the factory wire is empty, the corresponding patch wire in the v4 harness is unused. I in the picture below we removed two unused wires the red patch loom. Although you can take wires from any patch loom. Even in the same yellow patch loom. Just make sure it is unused! Step 4 Insert new patch wires: Step 5 Fold up and tape old wires for later use: Last edited by OpenFlash; 11-04-2010 at 06:13 PM.. |
11-03-2010, 07:41 PM | #4 |
Rep 6,594
damn, i need to get my DME software updated.
11-03-2010, 07:52 PM | #7 |
1750
Rep 17,960
Drives: A Lot
11-03-2010, 08:26 PM | #8 |
442
Rep 18,331
Yes I need the sim for 02 readiness or I will never pass inspection...Shiv whats the deal for people like myself if I do this update, well first I have to get the software updated which I am reluctant because my car runs like a charm....Can you let me know if this harnass update is going to effect my nitrous system or would it work without it and will be used for something else?? Either way If I do this update how will I get 02 readiness to pass inspection??
11-03-2010, 08:28 PM | #9 |
Rep 3,345
good point.
Brentuning Cobb AP pro tune -IG: @beemeraddict 2010 335i zmp fbo, 465/513 E60 mix |
11-03-2010, 08:42 PM | #10 |
1750
Rep 17,960
Drives: A Lot
Those who must, for whatever reason, have their off-road-only-use race cars achieve readiness every 4 years need only undo this mod when that time comes
11-03-2010, 08:51 PM | #11 |
Rep 1,659
11-03-2010, 08:51 PM | #12 |
442
Rep 18,331
lol...NY state requires inspection every year! I will hold off on this update to see what the goodies are going to be in the future and then decide to update my DME software...Shiv can you at least give us some clues to what this input will be for? Well at least your title of thread says OPTIONAL!!! lol I am so happy with the way my car is running right now...scared stiff to get new software...well see
11-04-2010, 01:32 AM | #13 |
Rep 7,377
what are most people running for value in the 02 modifier? 50%?
11-04-2010, 01:40 AM | #14 |
Rep 1,311
O2 modifier set to 50% works perfectly well in my car and I'm not using the BMS O2-sim at all.
Shiv, will the existing Procede O2 modifier function work after this harness modification? |
11-04-2010, 02:55 AM | #15 |
Rep 529
Shiv, there are a lot of people that will not be able to pass emissions if they do this update. CanClear does not allow OBDII readiness to be set. Many states require OBDII emissions testing every year. Some exhaust systems with high flow cats will also fail due to very specific O2 band that DME is looking for. Built-in adjustable O2 simulator is one of the features that attracted many people to the Procede.
11-04-2010, 03:00 AM | #16 | |
1750
Rep 17,960
Drives: A Lot
Shiv |
11-04-2010, 05:28 AM | #17 |
Rep 3,345
ok cool, but are you going to use that input for something else in the future we may need? if so what will we do then?
11-04-2010, 05:33 AM | #18 |
54
Rep 886
Yep, 50%.
CANclear doens't work with my car, so I won't be doing this update. I once asked bmw dealer to update my DME, but they refused and told this wasn't necessary.
Mods: RB turbos, JB4, BMS DCI, Scoops, Forge DVs, ar design catless DPs, Milltek exhaust system, Helix FMIC, Quaife LSD, VK MotorWerks OC Kit, Bilstein B16 PSS10
11-04-2010, 05:48 AM | #19 |
Rep 1,617
More info on the future use of these channel would be very welcome before doing this modification.
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
11-04-2010, 08:04 AM | #21 |
442
Rep 18,331
Shiv would you be able to sell a external o2'modifier or can we use one of those already available for those of us who will want to update the harness in the future to take advantage of the future and still have the old dme programs?
11-04-2010, 08:16 AM | #22 |
Rep 7,377
I would suggest you to get the BMS 02 sims but i am pretty sure you would prefer to put a dead mouse in your ECU box over that
