E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > E90 M3 diff on a 335i?
Reply
      11-04-2010, 08:14 AM   #1
chesney72
chesney72's Avatar
Scotland
27
Drives: JB4 G5 335i Sport Touring
Expecting this to be "NO" but thought I'd ask.
335i is a nice car and good fun but I reckon a good LSD would add to that. The M3 has a proper LSD so could this be fitted to a non M3 E90/91
Other option is the Quaiffe I suppose.
      11-04-2010, 09:21 AM   #2
JayKay335i
Egypt
204
Drives: ///M323 DCT
Search. Somebody fitted an m3 diff. Not sure if it was e90 or e46. The aftermarket ones are also good choices.
      11-04-2010, 09:43 AM   #3
chesney72
chesney72's Avatar
Scotland
27
Cheers,
It's purely as I've seen an M3 rear diff advertised and thought it would be easier to just swap the whole diff rather then fit an aftermarket one.
Will it affect the final drive ratio though?
I'll do a search or if anyone else finds the link please let me know.
      11-04-2010, 10:08 AM   #4
fl335i
fl335i's Avatar
Drives: 335i
subscribing... Had the same thought the other day. Why spend 3k and all the labor to put a LSD in my 335i when I could maybe swap out for a M3 diff assy from a wrecking yard.
      11-04-2010, 10:24 AM   #5
Jake C
Drives: 2009 335i 2010 335d
http://www.e90post.com/forums/showth...hlight=M3+Diff
- J
In Memory of LeRoi Moore 1961-2008.
      11-04-2010, 11:03 AM   #6
chesney72
chesney72's Avatar
Scotland
27
Originally Posted by Jake C View Post
good man thanks!
Doesn't appear to be a straight fit but do-able! Will read it through but I presume the rear end is the same for manual and auto and it would be the driveshaft length that would be different.
      11-04-2010, 11:57 AM   #7
fl335i
fl335i's Avatar
Drives: 335i
Looks like exactly as he said. Diff, shafts and d-shaft. I think I'm going to go this route. I rather have OEM parts vs aftermarket whenever possible. Not to mentions if I have a LSD installed in my curret diff, I'm paying for labor, shipping... vs paying for parts. I rather pay for OEM parts, not labor.
      11-04-2010, 12:57 PM   #8
Kevin Harney
Drives: 2009 335i Convertible
Nice link Jake !!! Thanks.
      11-04-2010, 01:42 PM   #9
chesney72
chesney72's Avatar
Scotland
27
Only part of the M3 method I don't like is the gear ratios changing so cruising in top will be at higher rev's.
      11-04-2010, 01:58 PM   #10
Kevin Harney
From what I read it did not seem to be a significant change. Did I read wrong ? ie 3.08 to 3.15 ....
      11-04-2010, 07:46 PM   #11
MKE_M3
MKE_M3's Avatar
Drives: 2011 e90 M3
I think an aftermarket diff designed for yuor car's rearend is probably a lot less complex and less labor than fitting a diff not designed for your car's rear end. My 2 cents. I am waiting for a wavetrac LSD that I got for a good deal through a group buy. I expect the all in cost to be about $1800, including labor.
      11-04-2010, 08:44 PM   #12
e90TiAg335i
e90TiAg335i's Avatar
Drives: 10 e90 335i
2010 e90 335i  [7.00]
That would be true unless you have a welded ring gear like mine. Then it's probably cheaper going the m3 route. The only labor you'd have to pay for is the driveshaft cutting and balancing. I'm definetly going the m3 route when I come across the right deal!
JB4, DP, VMR V710, Sonic Tuning S1 coilovers, Hybrid Ovations, Soundsplinter 10" and Zapco DC Ref amps
      11-05-2010, 07:58 AM   #13
fl335i
fl335i's Avatar
Drives: 335i
If you got welded gears, so much better. Not only is a LSD, it's re-geared and OEM quality. +1 for the M3 diff. Just more of a PITA to find a the parts at the right price.
      11-05-2010, 08:46 AM   #14
STONEY_M5
MAAD HEAD
STONEY_M5's Avatar
Drives: 2010 X5M 2013 M5
13 F10 M5  [0.00]
2010 X5M  [0.00]
07 335i  [9.26]
+1
F10 M5 e70 X5M
Sold E90 335i
      11-05-2010, 03:43 PM   #15
GeorgeSmooth
GeorgeSmooth's Avatar
41
Drives: 2008 E90 335i AT
Originally Posted by M335i Oreo Package View Post
+1
You also need to buy the M3 driveshafts as the 335 has a different bolt patern.
08 E90 335i AT RB Turbos -NX Wet Kit - Chiplogic Flash or Procede V5- M3 Diff - AE Exhaust- Forge Dv's - Helix Intercooler - AR DP's - P3 Boost Gauge - Vishnu Meth- Stett Chargepipe and CAI
09 C63
      11-05-2010, 04:03 PM   #16
e90TiAg335i
Drives: 10 e90 335i
You'd only have to buy the rear half of the m3 driveshaft and cut down the front driveshaft from the 335. Then have them balanced.
      11-05-2010, 07:24 PM   #17
MKE_M3
MKE_M3's Avatar
Drives: 2011 e90 M3
I'm not sure why you think the labor will be less. Cutting drive shafts, installing differant axles, etc. is all work you don't need to do with teh Wavetrac kit for welded diffs.
      11-05-2010, 07:26 PM   #18
MKE_M3
MKE_M3's Avatar
Drives: 2011 e90 M3
Perhaps someone who did the M3 swap can quote what their "all in" price was. BTW, I would much rather have the M3 diff than quaife or WaveTrac as it is one of the best LSDs on teh market, supplying nearly 100% of torque to the wheel with the most traction. I didn't go that route because I expected it to be far more complex and expensive. If I was wrong, DOH!
      11-06-2010, 12:55 AM   #19
klipseracer
Drives: 2007 E90 335i, 05 E46 330i
2007 335i  [0.00]
2005 330i  [0.00]
Its been done, and you'll just have to be able to live with custom and warranty issues... In all honesty, with a welded diff you're better off sourcing some m3 parts and living with the ratio change. Otherwise just go get a wavetrac. There is or was a great group buy going on. I wish I had a LSD
      11-06-2010, 05:39 AM   #20
e90TiAg335i
Drives: 10 e90 335i
Because all I'd have to pay for is the driveshaft modification and balancing.
      11-06-2010, 06:25 AM   #21
GeorgeSmooth
41
I know. I am the only one that has done this thus far.
09 C63
      11-06-2010, 12:13 PM   #22
MKE_M3
MKE_M3's Avatar
Drives: 2011 e90 M3
How much, all in, did it cost? How much work did you do yourself? It would really help the community if we knew more details.
Reply
e90post
