Did i screw up my ******** BOV install?
11-05-2010, 12:22 AM | #1 |
Rep 334
Here is my setup, i think ive done it all wrong, something is leaking some oily looking fluid around the base of the charge pipe. let me know what to do thanks.
I routed one of each nipple to the Y in the picture, please tell me im doing something wrong |
11-05-2010, 03:40 AM | #2 |
Rep 70
I've never installed a BOV, so I'm not sure about the Y to the vacuum tubes, but as far as I can tell, you're install is fine...it just looks like you need an OIL CATCH CAN...
11-05-2010, 09:08 AM | #3 |
Keepin' America Free
72
Rep 1,260
Yea the charge pipe can get oil in it which will then leak out of the BOV, it is normal though. An aftermarket catch can will fix this.
F10 535i | Retired: E60 ///M5 | E92 335i
"If everything seems under control, you're not going fast enough" -Mario Andretti |
11-05-2010, 09:10 AM | #4 |
Rep 1,222
It's the oring from the stock did you remove it and put it in the z shift bov? I have my setup and that is a lot of oil to be leaking out of it after just installing.
11-05-2010, 10:32 AM | #6 | |
72
Rep 1,260
Just curious what you're other vacuum line is going to? Boost gauge?
11-05-2010, 01:40 PM | #9 |
72
Rep 1,260
Idk that particular BOV, but most usually only need one vacuum line. I could be wrong though.
11-05-2010, 01:50 PM | #10 | |
Rep 3,012
11-05-2010, 06:48 PM | #12 |
COBB'ed
65
Rep 2,228
Is all of that oil leaking from the throttle body/pipe connection? If so did you reinstall the OEM O ring from the stock pipe into your new pipe. Also some oil blow by is normal on these engines, try an aftermarket oil catch can. I recently installed a bov kit on my car, I went with the Synapse kit and I get some blow by as well, comming out of the bov itself, but definately not as much as you are. Hope this helps.
13 Mini Cooper S 08 E92 335i (SOLD) |
11-06-2010, 01:16 AM | #13 |
Rep 3,012
The front nipple goes directly back to the nipple by the throttle body. The only reason for a Y is if you have a boost gauge or some other mod that requires a boost signal. I'm drunk so I may be forgetting something, FYI lol.
11-06-2010, 03:06 PM | #14 |
Rep 1,054
Ok you are suppose to keep 1 diverter valve in the back connected and run the second line out the back to the back of it. I don't know why but thats what it calls for.
some folks leave it out and thats ok but I run high boost and I want all the support I can get. the line from the back of the BOV goes to the nipple of the rear diverter valve. leave the rear dv plugged up to the intake and cap the bottom of the DV ( the part that went in the stock charge pipe). Good luck, mine is working fine... holding 18 psi but is too loud for me as Daily Driver. I am selling mine with like 50 miles on it and going back to diverter valves. pm me if you are interested and I will even help with install. OH I bought a blue horn for mine so it looks different than everyone elses....
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
11-10-2010, 08:45 PM | #18 |
Some say...
239
Rep 4,296
Drives: Fresh
I am pretty sure a little oil is normal since crank pressure is vented into the intake. As for the vacuum line, there should be one vacuum line total and it should go to the top of the BOV, the bottom nipple is left open, no tube connects to it.
I have exhaust and an intake... |
11-11-2010, 09:16 AM | #19 |
Black on Black on Black.
38
Rep 532
My CP was always completely covered in oil prior to installing a catch can, it got to the point that my Stett CP would blow right off the intercooler side under boost.
Get a catch can pronto; Your car will love you for it. |
11-30-2010, 04:48 PM | #20 |
Rep 1,054
someone forgot to put the o ring in place.... this happens alot when folks buy a charge pipe that comes with no instructions....
Take the rubber o ring out of the stock pipe, put it in the mouth of the new pipe...
11-30-2010, 05:16 PM | #21 |
Rep 1,922
Drives: 2021 G80 M3
+1. don't forget the O-ring and also OCC is a must.
