How to turn on "valet mode" in latest procede v4 software
11-05-2010, 01:53 PM | #1 |
Rep 172
Hi,
I have downloaded the latest 4.20 software for the procede v4 but I cant find the option to activate the valet mode. In the previous software this option could be found in the User adjustables. Does anyone know where I can activate it now? Thanks! Old software: Latest software: |
11-05-2010, 01:55 PM | #2 |
52
Rep 428
Howdy-- you don't active or switch maps in the user software. That is all done through the cruise control stalk or DTC button (if you have the DTC mapswitching feature enabled). Very simple.
11-05-2010, 01:59 PM | #3 | |
Rep 7,377
just double click the DTC button till the rpm needle shows 0 rpm. If it is 1000 is map 1 , 2000 map 2
11-05-2010, 01:59 PM | #4 |
Rep 172
I read everything, but in the previous software you had to turn valet on (typing a "1" in the user adjustable parameters).
I was just missing the option in the software. I guess it is not needed anymore. Thanks |
