Procede settings question
11-14-2010, 07:12 PM | #1 |
Rep 1,284
I got my procede, after the install what am I suposed to do in that user adjustable parameters table ? I have all the bolt ons + meth , I want the most power lol
11-14-2010, 07:49 PM | #5 | |
Rep 6,631
If you want to be safe FBO+meth assuming it's flowing properly, go UT65 IC0 max boost 17psi.
E90 LCI N54 6AT
11-14-2010, 07:56 PM | #6 |
442
Rep 18,331
Those settings would recommend! Its like sending it up the river without a paddle!! lol
11-14-2010, 08:12 PM | #7 |
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
-I would go UT-75 IC-0 & max boost 18psi with your setup.
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
11-14-2010, 08:15 PM | #8 |
Rep 6,631
He has probably the same level of mods I do, and I went 18.5 and timing was still maxed out. Without knowing what size the OP's nozzle is though, I can't recommend it wholeheartedly.
E90 LCI N54 6AT
11-14-2010, 08:25 PM | #9 |
Rep 2,663
I'm completely stock and ran fine with 100 octane at UT-70 IC-0 for a few days when I had the tank full of it. With full mods he can go well beyond that, but if he's looking to be safe and have full power I would stay below 18psi.
Autotune tunes your car anyways, just have your boost limit at 18psi.
11-14-2010, 08:43 PM | #10 | |
Rep 6,631
Honestly, set the UT to correspond with the boost level you desire. Autotune at that point can work its way down if conditions worsen but will not increase beyond your set limit.
E90 LCI N54 6AT
11-14-2010, 08:52 PM | #11 | |
442
Rep 18,331
11-14-2010, 08:58 PM | #12 |
Rep 2,428
The smartest thing would be to let autotuning do its thing on the respective maps. If you do get autotuned to crazy high boost, lower the max boost setting.
11-14-2010, 09:34 PM | #13 |
Rep 1,284
I have cm10 nozzle, I used to run map8 on jb3, so basicly I should put maximum boost on map 2 18 psi overboostdelay leave as is , ic - 0 and let it autotune , how about these settings bellow ?
autotune agression ? user boost ? 1st & 2nd gear tq map ? autotune agression ? wg position? |
11-15-2010, 08:40 AM | #15 |
Rep 1,925
Drives: 2010 135i,1989 PRO3,2001 530i
i met a guy that set it to 19psi on a completely stock car!!! hahahaha, what a fucking idiot!!!
135i coupe 6MT TiAg ///M sport http://www.rhominnovations.com www.musicarNW.com www.unitedBMWonline.com |
11-15-2010, 08:45 AM | #16 |
Rep 83
silly question... what is UT ?? Initial boost ?
Procede V5, AMS FMIC, AR c-less DPs & Borla exhaust, DCI, CDV, STETT Charge Pipe+BOV, KW CoilOvers, CMGS Meth kit CM10, AR additional oil cooler, Quaife LSD, TD stage 1 turbo upgrade, RIX Gauge, ACT street clutch
11-15-2010, 11:21 AM | #17 |
Rep 1,284
11-15-2010, 02:02 PM | #18 |
Rep 2,320
first i would recommend to change your signature
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
11-15-2010, 02:09 PM | #19 |
3442
Rep 79,211
Map 1 (Leave it alone)
Map 2: Max BOOST "18" PSI Overboost Delay "Default Settings" Initial boost "65" (means 16.5 PSI) Ignition correct "10" (Always start conservative). 1st Gear Torque I run 50% could run 60-75 in summer or 100% if you like spinning first gear. At track on drag radials you can run 100. 2nd gear torque, "100" Upshit softening leave it where it is. (Default) Autotune aggression "2" (Default) When you get your failsafe in... let me know, you will want to change injection mode at that point. |
11-15-2010, 02:41 PM | #20 | |
Rep 1,284
11-15-2010, 02:47 PM | #21 | |
3442
Rep 79,211
In procede program you want to enable Debug byte 7 in the channels its meth flow. When you test the meth flow, this value will read a number, somewhere between 12-18 I would gather. As meth is flowing you will find that number, say its 14... So now you have a 14 flow in "optimum conditions" (not under boost). When under boost its likely you might flow only 13.... So you set your minimum flow to 12 in "injection mode" Cliff notes: Open Procede Program Go to Logging channels Insert Debug Byte 7 so you can view it on the top right of the procede main screen. It should read 0 with no meth flow. Hotwire meth to flow into a CLEAN bucket or very large cup to test meth flow and find optimum number. (if the bucket is squeaky clean u can resuse meth) Take that optimum number and subtract 2. Insert that number into "injection mode" under user adjustable tab. The latest firmware/maps (firmware 31 if available to you) uses the following maps... Map 1 (is map 1) Map 2 (is map 2) Map 3 (N/A Mode) Map 4 (Progressive meth map) When on map 4, your blinkers will illuminate showing methanol is flowing. You can also datalog your car, and read the output of debug byte 7. If your on older firmware like 29 Map 1 is 1 Map 2 is 2 Map 3 is progressive Meth map, again blinkers will illuminate when methanol is flowing over "12" injection mode. Labonte failsafe has 3 wires.... Red Power black Ground Green (NOT USED) blue(To Procede). |
11-15-2010, 03:11 PM | #22 | |
Rep 1,284
