Overheating Issues
11-18-2010, 09:04 PM | #1 |
Railside Performance
48
Rep 331
Drives: E92 M3 R8 V10 Q5
Garage List 2010 Ducati Streetf ... [7.00]
2017 Q5 [0.00] 2017 BMW R NineT Racer [5.00] 2010 Audi R8 V10 Ma ... [0.00] 2008 M3 [10.00] |
Overheating Issues
I have an 06 325i with 200000km and had intermittent overheating today with the common red symbol shortly after no more heat from the vents and the vent cap leaking. I stopped the car, let it cool and it would be good again for the remainder of the trip with heat in the vents and no warning light. I did alot of searching and it seems to be related to the electric waterpump and thermostat or possibly a battery issue. I did the waterpump test with the key on/engine off with foot to the floor and could hear the waterpump turn on for a second and then stop and this would continually cycle until I shut off the car. I ran the car for a few minutes and the fan was running but would spool up fast and then go slow, then fast and slow continually in what seemed in tune with how i heard the waterpump earlier on. Sooo.......is the waterpump fried or might i luckily have an electrical issue or bad battery. The battery was weak when i bought the car 14 months ago was was recently unhooked a few weeks ago for exhaust work but the terminals seem fine. I appreciate the help since this is my only car and daily driver.
11-18-2010, 09:34 PM | #2 |
Rep 701
Sorry for you problem man, BTW, that's the wrong part. It's about $300.00 short of the real part. Here's the link.
http://www.trademotion.com/partlocat...layCatalogid=0 |
11-19-2010, 07:30 AM | #3 |
Rep 46
Similar issues here
I have a 2006 325xi and had similar issues last week. Get this too, my car only has about 40k miles, which in my opinion is far too soon for the pump to fail. Anyhow, yesterday, I bought the water pump ($300), Thermostat ($70) and aluminum screws ($5.00); tax and all about $405 - ouch! This doesn't include labor yet!
Good luck dude! |
11-19-2010, 08:00 AM | #4 |
Rep 5,018
Drives: VALNCYA
200,000 km wow man any other issues? sounds pretty well built
11-19-2010, 12:54 PM | #5 | |
48
Rep 331
Cheapest pump I have found in Canada is 450 so far. Bartmnan619 is right about Rockauto listing the wrong part....damn |
11-19-2010, 01:03 PM | #6 | |
Rep 2,783
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
11-19-2010, 07:28 PM | #7 |
48
Rep 331
Nope. I bought the car used so I am unsure when the last time the coolant was changed. I drove home tonight and within 5 minutes I lost heat but turned off the car when driving (unsafe I know) and turned it back on and regained heat. Lost heat 5 minutes later and repeated the same process then drove 20 minutes home with no issues?? I just want to make sure it is the pump since the dealer has the pump and thermostat in stock and I want to be sure this is the problem before blowing 7 bills tomorrow morning.
