jb+ question
11-23-2010, 09:29 PM | #1 |
Rep 99
jb+ question
Is the jb+ the simplest way to pick up 40- 50 HP? It seems to be easy to install and more importantly easy to remove when the hpfp goes and you have to visit the dealer. Will it truly not show any codes if kept to middle default setting?
11-24-2010, 09:55 AM | #2 |
Rep 10,858
It is the simplest & easiest, but don't expect more than +20-30 HP at anything but the max (code causing) level.
IMO if you are capable of restraint, and keeping it at <40%, you are keeping boost close to max stock levels for high altitude. For a couple hundred $ it provides similar pop as the BMW Perf tune, albeit without the cooling. Even at mid-level you are risking codes. ISTA is watching you. If you are interested in more power then invest in a tune that will protect your engine.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
11-24-2010, 10:44 AM | #3 | |
Joint Chiefs of Staff
4927
Rep 116,037
Mike |
