Increasing the NA side of the 335i?
11-29-2010, 09:48 PM | #1 |
Rep 63
Hey all,
I'm curious. How much could you get out of the 3.0L NA? Such as camshafts, different pistons, etc. Then, add the flash tune for the twins. Has anyone begun doing these types of mods? Everyone seems stuck on flash mods and I haven't seen many NA mods besides intake/exhaust. Or is the car still too new? Update: Rephrased the original post Brent Last edited by brentseay; 11-29-2010 at 11:29 PM.. |
11-29-2010, 10:08 PM | #3 |
Rep 63
The old 318i M44 1.9L you could take to 2.1L with a crankshaft swap and some new pistons. The 325i you could build up. You could swap out intake manifolds, etc.
Has anyone tried to actually build the 3.0L engine into 3.2L or similar? More to modding the performance than just throwing xbox-style firmware updates at the car is all I'm saying. Brent |
11-29-2010, 10:11 PM | #4 | |
Rep 6,595
11-29-2010, 10:35 PM | #5 | |
Rep 809
11-29-2010, 10:41 PM | #6 |
Rep 2,090
uh whats so confusing about it?
i havent seen anyone really mess with the internals of our engines as of yet..
11-29-2010, 10:45 PM | #7 |
Retired e90post Member
135
Rep 3,038
Yeah haven't heard of any company messing with internals or anything like that.
I bet HPF already looked into it, if they're going to make these n54s beasts. |
11-29-2010, 10:57 PM | #8 |
Rep 1,661
+1
07' MT, Quaife LSD, BMW Performance LED Steering Wheel, HPF FMIC, AA BOV, HPF Exhaust, DCI, Procede V5, AR Stage 1 oil cooler, AR OCC, AR CL DP's, Vishnu Meth Kit, UUC SSK+DSSR, UUC Shift knob, (19 inch)VMR V715's/Yokohama Advan AD08's, Hartge Pedals and Floor Mats. Awaiting Install: M3 Rear Subframe Bushings, Full M3 suspension bits, AST 4100's, DSS axles. Future plans: Vishnu Single turbo kit
11-29-2010, 11:12 PM | #9 |
Rep 1,271
Honestly, I understand since I came from a world of building an NA mustang. But with a 335, having a tune is the best hp per dollar and there is nothing else out there that comes close. Getting 80 wheel hp for roughly $500 is unheard of with an NA engine. And when I think of possibly doing heads, cam, etc, the cost per hp would be astronomical compared to the cost of a tune. And then worrying about warranty issues..... its easy to take a tune out.
2007 335i Jet Black e92 6AT - VRSF Full street exhaust DP, Chargepipe 7.5 FMIC, MHD, XHP, Koni orange/Eibachs, some other stuff
2007 335i Jet Black e90 6MT - Eibachs, magnaflow exhaust, carbon hood, short shift kit, some other random stuff - being sold somewhere sometime soon probably 2010 335i AW e90 6 AT Msport - The GF took this one over... JB4, PE exhaust, Koni yellows/Eibachs, pink badges, fuzzy steering wheel cover ? |
11-30-2010, 12:52 PM | #10 |
Rep 238
Drives: F30 335i
racing Dynamics sells internals for the n54. They have a sweet, body kit too.
11-30-2010, 12:57 PM | #11 | |
Rep 134
11-30-2010, 12:59 PM | #12 | |
Rep 10,587
11-30-2010, 01:01 PM | #13 |
Rep 1,922
Drives: 2021 G80 M3
take a look at VAC motor sports. They have alreadu started. they already have a stage 1 and 3 cylinder head.
11-30-2010, 01:26 PM | #14 |
Rep 134
11-30-2010, 01:54 PM | #15 |
Rep 1,809
It would be interesting if some tuning company would dare to increase the engine displacement via new forged rods/pistons to something like 3200cmc and lower the compression ratio a bit. With upgraded turbo housings the engine may be capable of some big numbers.
12-01-2010, 04:14 AM | #16 |
Rep 2,563
Actually, internals for the N54 have been available for quite some time.
About a year ago I asked a German tuner about this and he told me that he could procure the forged low compression pistons that Mahle uses on the Alpina B3 (S) Biturbo. The lower compression (9,4:1) will not give you more power (less actually), but the lowered compression ratio will decrease the danger of knocking. The same is also available from the Austrian company Pankl Racing. They have two brands, CP and Carrillo. CP is able to manufacture the forged pistons - either as an upgraded stock piece with the same compression ratio but sturdier materials, with the above mentioned Alpina compression ratio or a custom compression ratio that you can choose yourself. VAC Motorsports sell them under this link for around 1000 USD. Under the brand Carrillo, Pankl is able to manufacture upgraded rods - either in steel or (much more expensive) in titanium. The former are again sturdier than the stock pieces and may be an option for very high powered N54 engines, the latter improve the revving characteristics of the engine and are even stronger. I don't know the price of these, though. A friend of mine is already running the upgraded low compression pistons and rods for some time, and I'll most likely install them at the beginning of next year in my car. Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
12-01-2010, 06:33 PM | #17 | |
Rep 1,035
Here is an example of a similar situation but on a different vehicle. I build late model mustangs on the side. I have a built stock cubic inch bottom end in my cobra, with stock heads/cams/intake and a 76mm single turbo. My car @ the time of this comparison made 740rwhp@ 25psi through a 6 spd. I built another Cobra @ the same time, same exact bottom end. However this car had fully ported heads, valves and all upgraded valvetrain. Custom billet cams spec'd out for this particular setup and a ported intake manifold. Car runs the same 76mm turbo, on the same dyno, with the same tuner. This car made 860rwhp@ only 21psi! So that was a 120rwhp increase running 4 less psi! PLUS the car was much more responsive and spooled quicker then mine did as well. So yes, upgrading the internals/valvetrain on an FI car is very very beneficial with the correct parts. @ what cost though, that is a different story. The motor in my example alone was over $12,000, and thats for a mustang where parts are much much cheaper and more readily available. |
12-01-2010, 07:17 PM | #18 | |
Rep 134
12-01-2010, 09:00 PM | #19 | |
Rep 1,035
Heck on a setup on my cobra, a set of custom ground cams would gain me 75-100rwhp. I have customers all the time that do not hesitate to drop 20, 30, 40 even 50k into their mustangs over the period of a few years time to get it to where they want it to be. Those cars will also put a hurting on a GTR, GT, ZR1 etc etc. for less money. You have to pay to play. If all you want is a few extra HP, then bolt ons it is. For the not so average guy that is willing to go the extra step, its going to cost money, no matter what type of vehicle it is. The OP wanted to know if people were doing things such as strokers, cams, etc, you chimed in it wouldn't make a difference. I corrected your statement because it is 100% untrue, and this is how false information gets spread around all over the internet. How do you know he doesnt have some cash to spend and wants to push his car further then the other 99.9% of the people on the board that are stuck on Boltons? Read what you wrote again "N/A Mods as one said before would not help a great deal if even at all. The only positives to messing with the actual block, head and internals would be to strengthen it too endure high HP output" So how should I have interpreted this? Stick to bolt ons because everything else would be a waste? |
12-02-2010, 11:51 AM | #20 | |
Rep 10,587
Here is a great example of what you just posted but using a boosted 6cyl BMW motor. posted this in another thread BavSol head and cams vs stock head/cams huge difference all around ====================== BavSol cams idling, obviously aggressive: dyno charts showing gains, also aggressive :
12-02-2010, 02:12 PM | #22 |
Rep 267
Drives: 2007 E93 Alpine white with Red
It's Obvious that Juiced 46 knows what he's talking about and some others simply dont. I too spent a lot of my time building mustangs. Ended up with a 331 stroker with ported heads, port matched intake and headers, 3 angle valve job and a cam that I spent more time stressing over the duration and lobe separation angle figures than I'd like to admit. if I had forced induction - forget about it - it would have been nasty! Why? The easier, and more efficient an engine can pump air in and out, the more power. It's simply an air pump! If you have 25 pounds of boost running through a garden hose to get to your cylinder, imagine what a fire hose to your cylinder would be like with the same boost?
2007 335I E93 sport package Alpine White. BMS DCI, PROcede V4, ACT street clutch, Michelin Pilot Sport A/S Plus and BT Tool. Pending install of Raceland Downpipes.
