PROcede Autotune FBO / 93 octane no meth - advice needed.
12-04-2010, 11:09 PM | #1 |
Rep 6,631
Hey guys:
I was wondering if someone could help me out regarding this issue I'm having. As many of you east coasters know, the weather is frigid out there, so I would imagine that boost should skyrocket up to the max value in this weather with no ignition correction. The log is of a 3-4-5 pull shifting at 6000 RPM. On my former 135i, I would see 15.6 psi / 31 ignition correction autotuned with no meth in HOT temps. In this case, I reset autotune adaptations, started my autotune figures at 15psi boost, 50% ignition correction, and after a few pulls, it dropped autotune figures significantly, to 14.2 psi / 77% ignition correction, although the aggression value stabilized at 2.0. I filled up with the same Gulf 93 octane from the same station as my higher 135i autotune settings hit. I just got this car, and this is my second fill-up, both from the same station. I have attached both a log and video of my run. Fuel Pressure as per Shiv's instruction, is just around 3.9 - 4.1V, which is within spec. boost looks clean, and ignition correction is cutting about 3 degrees of timing to ensure a smooth curve. Boost targeting vs. actual boost is a bit high though. I had this same phenomenon on my 135i (target 18psi, see upwards of 18.6ish psi) The challenge I'm faced with here is... what could cause this? Bad gas? Boost leak? (highly unlikely) A few ideas based on these logs would be appreciated. Thanks....
E90 LCI N54 6AT
12-04-2010, 11:22 PM | #2 |
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
I'm seeing a similar effect with my boost gauge - haven't done any logs yet. I set the max boost to 14 psi but it autotunes to 11.5 psi. Hopefully someone will provide some insight.
I also had a random weird situation where I lost all boost. The car would not go into boost at all. I shut the car down, checked my DVs and charge pipe and they were all fine, started it back up and that resolved everything. Perhaps related to this, when I switched maps one time, the "map display" screen stayed on for an abnormally long time (more than 30 seconds). My car has a mind of its own so I wasn't surprised. |
12-04-2010, 11:24 PM | #3 | |
Rep 6,631
Never had an instance where I lost ALL boost though except in NA mode, that's definitely weird. I guess we'll wait for Shiv to chime in....
E90 LCI N54 6AT
12-04-2010, 11:28 PM | #4 | |
Rep 8,003
12-04-2010, 11:29 PM | #5 | |
Rep 6,631
I mean the car pulls reasonably hard without meth. I could go back out there set it to 17psi and spray meth with no failsafe... but I can wait.
E90 LCI N54 6AT
12-05-2010, 12:02 AM | #6 |
1750
Rep 17,960
Drives: A Lot
FYI, when it gets colder you are going to make the same power at lower boost. If it gets really cold, the Procese applies an IAT correction to lower boost. This is due to fuel system limitations at peak torque (3000-4500rpm). Nothing to worry about.
12-05-2010, 12:11 AM | #7 | |
Rep 6,631
So once I get my flow sensor back and set to 17psi, it will peg the boost limit and autotune down into the 0.x range assuming all is well in this cold weather?
E90 LCI N54 6AT
12-05-2010, 10:02 AM | #9 |
Rep 6,594
12-05-2010, 11:47 AM | #10 | |
1750
Rep 17,960
Drives: A Lot
So if your operational IAT temps fall into these two extremes, don't be surprised if you see a condition where your aggression level is lower than your aggression target and yet actual boost has not maxed out at your boost limit (ie, 17psi). |
12-05-2010, 01:02 PM | #11 |
Rep 2,842
Kind of makes sense that colder denser air at the same boost pressure is going to make more power......therefore more heat in the combustion chamber.
Also, many gas stations have switched over to their winter formulations, and I think this is showing up on a lot of people's datalog values in a negative way, so pump octane may be a factor as well. FWIW I am also running 14 psi on a mostly stock setup and find that 75% ignition correction seems to give me good timing curves. I think there is something to this colder weather requiring less boost/or more ignition correction since a number of members are reporting similar symptoms. |
12-05-2010, 01:19 PM | #12 |
1750
Rep 17,960
Drives: A Lot
Yep, that's pretty normal. Combine dense air charge/more power with reduced octane/higher fuel demands and you get what we are seeing. No biggie.
12-05-2010, 01:37 PM | #13 |
Rep 3,460
I am not seeing this with cold IATs.
dci/dp/fmic, high 20s outside and my boost shoots up to my 17psi limit instantly. My correction factor is also 0.2. What is wierd about your settings is that you are retarding alot of ignition. I can understand where boost drops down, but not an ic correction of 77. |
12-05-2010, 02:15 PM | #14 | |
Rep 6,631
With meth I bet it would peg the boost limit and stay there with really low aggression like you. I really don't want to run meth without a failsafe....
E90 LCI N54 6AT
12-05-2010, 02:24 PM | #15 |
3442
Rep 79,211
It was already said, but I was going to say, with cold air temps, the air is more dense, and thus more oxygen. So it takes less boost to make the same power.
12-05-2010, 07:20 PM | #16 |
Rep 6,631
on another note, do you think I am running extremely lean post-shift?
E90 LCI N54 6AT
12-09-2010, 11:07 PM | #17 |
Rep 6,631
Little update -
Prior to updating to V5, my autotune settings were at 12.7psi at 88IC. I always thought this was unusual, but after updating to V5, the default 13.5/50IC autotuned to 13.6/35IC after 1-2 short 3rd gear WOT pulls which is more like it. I did fill up at BP a few days ago just to try something different. Ambient temps were the same if not lower. Perhaps bad gas? Bad firmware update? I'm leaning more towards the former.
E90 LCI N54 6AT
12-09-2010, 11:13 PM | #18 | |
Rep 1,661
07' MT, Quaife LSD, BMW Performance LED Steering Wheel, HPF FMIC, AA BOV, HPF Exhaust, DCI, Procede V5, AR Stage 1 oil cooler, AR OCC, AR CL DP's, Vishnu Meth Kit, UUC SSK+DSSR, UUC Shift knob, (19 inch)VMR V715's/Yokohama Advan AD08's, Hartge Pedals and Floor Mats. Awaiting Install: M3 Rear Subframe Bushings, Full M3 suspension bits, AST 4100's, DSS axles. Future plans: Vishnu Single turbo kit
12-09-2010, 11:45 PM | #20 |
Rep 2,926
Drives: Cayman GT4, 135i
On map 1 with a Max PSI set on my car to 14.5 I have an Autotuned 14.2 and on map 2 with a max psi set to 16 i have an autotuned 14.5. however, When doing pulls in map 2 I constantly see 16 pis...
And i'm running Shell V power.
Current: M2CS
Gone but not forgotten: Cayman GT4, M2C, 2011 135i, E83 X3 6MT, 2016 SO M3, 2012 335iS, 2010 135i and 2006 e90 325xi |
12-09-2010, 11:49 PM | #21 |
Rep 6,631
Interesting. I never really run Shell gas because I'm a creature of habit (running Gulf gas exclusively) but I'll give Shell a shot. It's only 3 cents more than the Gulf station by me.
E90 LCI N54 6AT
12-10-2010, 03:14 AM | #22 | |
Rep 1,565
The amount of oxygen in the air is consistent, even at altitude. It is the partial pressure that changes, thus the molecules are denser/closer together, which provides for greater explosion/expansion upon ignition of the fuel/air mixture.
2020 M340i: Dravit Grey Mettalic. Loaded.
