Could bad coils be the cause of perceived knock/timing dropouts?
12-05-2010, 10:49 AM | #1 |
Team Zissou
3084
Rep 10,198
I recently had injectors 1-3 replaced (because #1 died). Since I've had the car back from the dealer I've noticed way more timing dropouts than I've seen before (only under heavy load, it idles perfectly fine/smooth), especially weird since the weather is so great now (low 30's at night). Last spring in much warmer weather my logs looked much better with higher boost.
Could partial misfires due to bad coils be causing this phenomenon, and is it possible partial misfires wouldn't throw a code? I've just recently passed 50k miles, the coils are the original ones (they were not replaced when I had the injectors replaced). |
12-05-2010, 10:55 AM | #2 |
Rep 5,876
Unless you get a code it's hard to tell...typically to figure out it's a coil you start swapping them around, changing places from say cyl 1 to 3, and seeing if misfire codes follow the swaps..if they do you know it's your coil..Possible your meth is puddling? I'd check that nozzle, when was the last time you checked it? Mr. 5 recently had similar issues only when on meth...try turning it off
12-05-2010, 10:58 AM | #3 | |
Team Zissou
3084
Rep 10,198
12-05-2010, 11:00 AM | #4 |
Rep 7,377
Yeah you should definetely change coils with 50k. Dont even think about it, just do it and yes that could be the cause.
12-05-2010, 11:26 AM | #5 |
Team Zissou
3084
Rep 10,198
12-05-2010, 12:45 PM | #6 | |
Rep 2,842
Seems like my car has been struggling to maintain smooth timing curves consistently. Some of the logs show perfect timing and then some show dropouts, even though I have not changed any parameters. To me it seems indicative of an intermittent problem that is manifesting once in a while. If you do enough datalogs you catch it when it happens. Sounds like that may have happened in your case. I suspect I have an injector or fuel pump on it's way out, which may give the occasional hiccup and cause a knock event to register. Right now out of three consecutive datalogs, one of mine will register a timing dip. For now I have gone back to old school and turned autotune off and am running higher octane and 75% ignition correction simultaneously to see if I can stabilize my timing curve to be consistent. If not, then I can be pretty certain that a fuel/ignition component is acting up. |
12-05-2010, 12:56 PM | #7 |
1750
Rep 17,960
Drives: A Lot
JP- I know it's a bit coincidental with your recent work at the dealership but could you also be seeing the effects of the winter gas formulation change? IIRC, they start rolling that in around October.
12-05-2010, 01:05 PM | #8 |
Team Zissou
3084
Rep 10,198
Past winters the logs have been solid, running pretty aggressive settings though. It's hard to compare, but I don't ever remember seeing it like this. I should probably change the coils anyways now that I'm past 50k miles no? It seems like dealers do this whenever they replace the injectors
12-05-2010, 01:16 PM | #9 |
1750
Rep 17,960
Drives: A Lot
Hmm... Then my only guess is that the new injectors weren't calibrated properly by the dealership. When you log wideband AFR, do both banks give nearly identical readings?
12-05-2010, 01:34 PM | #10 | |
Team Zissou
3084
Rep 10,198
How identical are we talking? What would you consider "strange"? For instance on any given pull, one bank is always .5-1 point higher than the other |
12-05-2010, 01:38 PM | #11 |
1750
Rep 17,960
Drives: A Lot
0.5-1 point is too big of a spread at WOT. They AFR logs should be almost right on top of each other. If one bank is consistently leaner than the other, that would suggest a miscalibration of injectors. Which makes sense since this issue only happened after 1 injector bank was replaced.
12-14-2010, 08:06 PM | #13 |
Does not play well with others
80
Rep 1,787
I am curious how do you monitor the timing? Is it with BT Scan or something else? I am having problems with the idle dropping out like a misfire and when I am acceleratintg i get little hiccups but no codes. Had isfire codes then went to dealership and they cleaned the valcves. Dont get the codes but still have the problems and thought it might havbe to do with the timing.
12-14-2010, 08:09 PM | #14 | |
Team Zissou
3084
Rep 10,198
12-14-2010, 08:41 PM | #15 |
Saving lives one shift at a time
19
Rep 309
JP- when you get a minute e mail me or PM me. I have to ask you something. Thanks.
Medic976@yahoo.com
2008 335i...... 6AT....Sports package.... Premium package.....Cold weather package....i Drive....Nav....Sat radio....Logic 7.....PROcede v4 auto tune....Injen Intake
12-14-2010, 09:26 PM | #16 |
Rep 693
i am having the same issue right now.
the car drives fine in stock map... once i put it on a higher boost map it misfires. I got a code for cylinder number five, i swapped the plug and still getting the code. im at 47k miles original coils. that site is a good find anyone else order from there?? |
12-15-2010, 03:28 PM | #18 | |
Team Zissou
3084
Rep 10,198
My issue is that I get no codes, and the car runs perfectly smooth... but there are just way more timing dropouts than before I went to the dealer for new injectors for the one bank. |
