E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Is there an easy way to center the stock tips?
Reply
      12-06-2010, 10:45 AM   #1
DH2117
Drives: 2011 335i M-Sport
I thought I should post this question with the exhaust experts. My stock tips are not centered from the factory. I think they are too far to the right. Is there a way to adjust the tail pipes or clamps? I would rather take care of this myself vs. wasting time going to the dealer.
      12-06-2010, 04:03 PM   #2
iBoost
Retired e90post Member
iBoost's Avatar
135
Drives: real slow
Ask your SA if a tech can check it out. You can tell they're far off to the right in the pic..
      12-06-2010, 04:10 PM   #3
e93WhiteonRed
e93WhiteonRed's Avatar
Drives: 2007 E93 Alpine white with Red
2007 335I E93  [0.00]
you need a BFH.
2007 335I E93 sport package Alpine White. BMS DCI, PROcede V4, ACT street clutch, Michelin Pilot Sport A/S Plus and BT Tool. Pending install of Raceland Downpipes.
      12-06-2010, 04:22 PM   #4
Ensi
Drives: 10' 335D
they are most likely off on the hangers, you just need to get under and look, the move the hangers on the mounts and it should stay for awhile. I always end up putting zip ties on the hangers to lock the mounts from moving....
      12-06-2010, 06:08 PM   #5
DH2117
Thanks, I will check. I tried to move the tips/mufflers, the unit wouldn't budge. I thought there might be bolts I can loosen to line things up? I have never seen a car this off from the factory. Manufacturing, shipping and VPC all went smooth with no delays. I assume this is a factory fit issue.
      12-06-2010, 06:13 PM   #6
n54fanatic
Armenia
149
Drives: M4
maybe youre looking at the tips off centered
      12-06-2010, 06:19 PM   #7
DH2117
No. That was my pre-delivery pic. They are definitely off center a good 1/2 inch or more. I don't expect them to be perfect in the bumper cut-out, but close.
      12-06-2010, 07:10 PM   #8
DH2117
Originally Posted by e93WhiteonRed View Post
you need a BFH.
What do I hit??
      12-06-2010, 07:51 PM   #9
ttbmer
Drives: space gray on black 07 335i
I just installed my ams exhaust and is way off!! My left tip is 1" farther out than the left. That happened when i put back that X brace there's under the car that one needs to remove to get to the exhaust. Is a pain in the ass but I need to find a way to fix that
PROCEDE, PWM Vishnu Kit, AR catless DP, BMS DCI, Helix IC, P3 gauge, 25% window tint, mattblack window trim, mattblack roof wrapped. Vorstainer CSL trunk, CF wrapped interior, 18'' Forgestar F14 Matt black, quaife LSD, M3 suspension bits, Mtech front bumper). http://www.youtube.com/watch?v=b8JIB8C8HDA
      12-07-2010, 08:33 AM   #10
Shieldze1025
Keepin' America Free
Shieldze1025's Avatar
Drives: F10 535i
Yea my Top Speed exhaust is a bit off. We centered it up but it has flexed since it heated up after being used, but I like the zip tie idea. I'm gonna prob do that.
F10 535i | Retired: E60 ///M5 | E92 335i
"If everything seems under control, you're not going fast enough"
-Mario Andretti
      12-08-2010, 05:28 PM   #11
Car Enthusiast
Drives: 2008 335i
I just bought 12" zip ties yesterday and gave them a try. I looped one zip tie around the exhaust piping on my left exhaust and connected it to two more loops of zip ties to form a little chain. I then attached and tightened the far loop through a circular hole in a rear cross-brace while having a friend push the exhaust over.
My exhaust tips look centered now, but I wonder how long it'll be before the exhaust piping gets hot enough to melt my poor zip tie.
Reply
e90post
