Question about battery safety terminal
12-06-2010, 03:20 PM | #1 |
Grozniy
179
Rep 2,602
Is it possible to bypass the BST or do I have to get a new BST cable? Does anyone know if the car needs any reprogramming after? I called my local dealer, they had no idea what I was talking about.
12-06-2010, 04:54 PM | #5 |
Kingslayer
411
Rep 1,479
It's located on the positive side. You can rig it to work (I won't get into how to do it but I will say that is not that difficult with a small screwdriver). If the BST has blown chances are you have an SRS light as well. Replace the cable and light with need to be reset.
Previous Cars: 2008' 135i, 2010' 328i, 2013' 328i, 2016' M235i, 2017' X1, 2019' M240i Current Cars: 2019' X3, 2021' M3 Comp |
12-06-2010, 05:58 PM | #6 |
Rep 541
What's wrong with it? If it's not blown, then it can be kept installed but removed from the SRS system with a simple resistor. If your light is set, only a reset will clear it. You'll need a dealer mechanic or a BavTech tool or similar.
12-06-2010, 06:38 PM | #8 |
Rep 7,089
Drives: '06 AW 330xi
It's cable? I thought it was that distribution block looking thing?
Anyone know of it will work with an non-OEM battery? |
12-06-2010, 07:06 PM | #10 | |
Rep 7,089
Should I just run a wire from the new positive terminal to the terminal of the red block? |
12-06-2010, 07:14 PM | #11 |
Grozniy
179
Rep 2,602
Not sure, but I think the red block is your BST
http://www.e90post.com/forums/showthread.php?t=292200 |
12-06-2010, 07:31 PM | #12 |
Rep 7,089
Ok, that whole black box connected to the positive terminal is red in my car.
12-07-2010, 10:18 AM | #14 |
Rep 7,089
I'm upgrading to this soon.
http://www.e90post.com/forums/showth...ghlight=braile Looks like they don't utilize the BST? Or am I still getting confused with the distribution block? |
12-07-2010, 12:25 PM | #16 |
Rep 7,089
^Well then. Is it that red thing attached to the positive terminal?
I've read somewhere that, that can be removed and a resistor can be used to prevent an error. |
