Waste gates problem
12-07-2010, 03:41 AM | #1 |
Rep 19
Waste gates problem
Hi I'm looking to purchase a 335i convertible 2007 with about 45 k miles. I took it to a specialist and he said the waste gates need to be replaced. Is this a big concern and can it cause future concerns if it's not attended too.
12-07-2010, 05:53 AM | #2 |
Rep 238
Drives: F30 335i
a procede will take care of this.
12-07-2010, 07:21 AM | #3 |
Mad Linux Guru On The Loose
1130
Rep 5,402
A procede will NOT take care of this. It will only mask the symptoms.
12-07-2010, 10:09 AM | #4 |
Rep 7,377
Depends if the problem is hardware or software related. Do you have rattling? Engine Cold, warm or both?
You cannot replace the wastegates, you need to change both turbos if the wastegates are not sealing. What did the specialist say exactly? Does he know how these turbos are built?
12-07-2010, 01:13 PM | #5 |
Rep 1,044
needs to be fixed as the proceed only masks the rattling sound. if the bushing are really worn you could get a low boost CEL from the wastagates not sealing. some dealers just replace the wastgates, some give new turbos, but either way it should be fixed.
12-07-2010, 02:10 PM | #6 |
Rep 19
Yea I do have rattling and engine cold. I thought it was just the muffler that was rattling because only one side of the muffler works currently. But when I took it to BMW they said the waste gates are giving the problems. From hearing this, do you believe it is a minor issue? Or one that can cause damage to the wallet in the future?
12-08-2010, 09:54 AM | #7 |
Rep 2,320
is it normal to hear rattles when car is cold?
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
12-08-2010, 10:16 AM | #8 |
Rep 5,538
Rattle #1 usually when driving slow, and when you start the car IS exhaust valve rattle. No big deal, just unplug the valve plug in the trunk. Dont really need it anyway.
Rattle #2 usually can hear when reving engine in N. This is wastegates. Can be a very big problem. Dealer procedure to fix: 1. Update all software, if not fixed: 2. Replace wastegates actuators, if not fixed: 3. Replace turbos Lots of people including me and DEALER confuse #1 and #2 |
12-08-2010, 10:21 AM | #9 |
Rep 267
Drives: 2007 E93 Alpine white with Red
Mine stuck open and the car wouldn't build boost over 3 lbs. replaced the whole turbo and actuator. MAKE sure the car is under warranty, otherwise it could cost you a few grand...
2007 335I E93 sport package Alpine White. BMS DCI, PROcede V4, ACT street clutch, Michelin Pilot Sport A/S Plus and BT Tool. Pending install of Raceland Downpipes.
12-08-2010, 10:23 AM | #10 |
Rep 703
i was just at the dealer this morning i had taken it in a while back and they reprogrammed it which lasted for like oh idk half a day it seemed. today i was back for vanos and a broken door lock and the dude came in and was like didnt you come in here for wastegates. i was like yeah but it didnt really do anything he was like omg ive never heard wastegates that bad i think we need to get you some new turbos!! =]
12-08-2010, 10:31 AM | #11 |
Rep 859
BMW refused to replace my wastegates under factory warranty. They denied they could even hear the noise. The month after my BMW warranty expired, I took it in to the dealer and they immediately claimed they could hear the noise and that my turbos needed to be replaced. I have an aftermarket warranty which covered it. The total bill was over $4000 ($100 deductible only for me). If it wasn't for my aftermarket warranty, I'd be suing BMW for this crap.
2007 335i SG Coupe
2009 128i AW |
12-08-2010, 10:46 AM | #12 |
Rep 2,320
my dealer not sais nothing about rattle when i visit them, maybe i dont have rattles
