Procede v5 vs Alpha JB4 on a closed track
12-09-2010, 11:50 PM | #1 |
Rep 2,926
Drives: Cayman GT4, 135i
One of my friend just got an Alpha JB4 unit. Our cars are EXACTLY the same. Same color exterior , interior. WE BOTH have 6AT Performance mods are the same Intake, Axleback exhaust, except he has JB4 i have Procede V5. He has his snow tires on while i have my summers on in this 23 degree weather. The only difference between our cars is that I have a full coilover / m front suspension and a LSD. But at a 60 MPH the LSD does not kick in. We did two pulls on a closed track. One with him being on map 2 I believe and me being on map 1 with a max boost of 14.5
Run 1: 3rd Gear Pull from 60-120. We were both Neck to neck at 120. at 120 he was gaining an inch but nothing noticeable. Then I switched to map 2(16 psi) and he switched to map 7(16.5 psi but he has max global boost set to 16). Run 2: 3rd gear pull from 50-130. Neck to neck till 130. (NOTE WE both did pulls in between to allow for adaptations when switching maps). We were not shocked at all. Our cars are exactly similar and are running the same amount of boost. Cheers =)
Current: M2CS
Gone but not forgotten: Cayman GT4, M2C, 2011 135i, E83 X3 6MT, 2016 SO M3, 2012 335iS, 2010 135i and 2006 e90 325xi |
12-09-2010, 11:55 PM | #3 |
Rep 2,926
Both have 6AT!
Current: M2CS
12-10-2010, 12:03 AM | #6 |
Rep 314
if they both have boost targetting now and running the same power levels etc,
then why before on the jb3 they would pull crazy on procede cars.. When the jb3 wouldn't have Boost Targetting??? |
12-10-2010, 12:15 AM | #7 |
Rep 6,631
rev.2 wasn't out two years ago. Different ballgame now.
E90 LCI N54 6AT
12-10-2010, 12:26 AM | #8 |
Rep 1,549
I wonder if snow tires affect the performance at all?
Thanks for sharing, also make sure you report back when he has the official JB4.
Embryo>e92
12-10-2010, 12:37 AM | #9 |
1750
Rep 17,960
Drives: A Lot
Now compare average knock with both cars
12-10-2010, 01:23 AM | #10 |
Rep 1,311
12-10-2010, 02:57 AM | #11 |
Rep 5,689
Its the same knock and for 99% of users it is not a issue so long as you follow the fricken directions and contact terry before upping anything and he gets back to you in 2 min any time of the day or year.
Also I ran high maps with no issues what so ever or knock codes as have many other users.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(1addicts.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
12-10-2010, 03:17 AM | #12 | |
1750
Rep 17,960
Drives: A Lot
For reference, us 91oct guys, running just 14-15psi will see average knock ramp quickly from the default autotuning target of ~2 to a very aggressive 4-5 once timing correction is eliminated. Which would be 2 to 2.5 times more knock retard. Which is unfortunate when that is considered normal operating. The next step in the test is to go back to running normal ignition correction and raise boost until aggression climbs to this 4-5. You'll probably see that the Procede can run 1-2psi more boost, with the same average knock, than a it did when it simply raised boost with no ignition retard. If anyone still, to this day, believes that proactive ignition retard has no effect on knock activity and engine safety margin, they are seriously deluded or just uneducated on basic engine tuning fundamentals. Running a tune without any form of ignition setpoint limiting is less desirable than running one with it. This is fact and can be proven with hard data by anyone with a CAN logging tool. Ignoring evidence and arguing otherwise only displays a lack of understanding or misinformed positive thinking. Last edited by OpenFlash; 12-10-2010 at 03:25 AM.. |
12-10-2010, 03:34 AM | #13 | |
Rep 5,689
Shiv, You are up almost as late as Terry lol Assembling meth kits still?
12-10-2010, 03:38 AM | #14 | |
1750
Rep 17,960
Drives: A Lot
Also fact is the effect ignition correction/setpoint limiting has on average knock. This is easy to quantify as I explained in my previous post. In octane limited conditions (ie, pump gas) running moderate to high boost, the less ignition correction you have, the more average knock you see. So if minimal knock is desired AND the ability to reduce ignition advance setpoint reduces the severity/frequency of knock holding all other things equal (octane, boost, conditions, etc,.) one can conclude that the ability to reduce ignition advance setpoint when necessary is DESIRED. This has been proven over and over again on this forum. There is no "magic bullet" that would allow anyone to argue otherwise. Engine tuning fundaments are just that, fundamentals. Saying that one doesn't agree with it is like saying that one doesn't believe that 1+1=2. I've up to my neck in meth kits. No time to sleep! |
12-10-2010, 03:52 AM | #15 |
Rep 5,689
I've up to my neck in meth kits. No time to sleep! [/QUOTE]
Get some small children to make them I will have to ask Terry about the knock issue. He has been 100% honest with me in the past as far as risk goes and no offense but you have a market to uphold where as I am just one customer (who doesnt even buy anything from him) so he has no incentive to be anything but. This is just conjecture but seeing as there are so many jb3 n54 cars with higher milage out there and no one has had a failure or major problem aside from the guys who are pushing the limits what are the actual effects of "minor knock", if it exists (dont debate this as I am not making a fact statement of any sort)
12-10-2010, 04:09 AM | #16 | |
Rep 2,320
as u may know that people who had jb3 (enrita, Big Tom) they moved to v5 ask why
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
12-10-2010, 04:10 AM | #17 | |
1750
Rep 17,960
Drives: A Lot
Shiv |
12-10-2010, 04:12 AM | #18 |
Rep 5,689
I will do my own research (as always) but like I said, terry has nothing to sell me.
12-10-2010, 05:10 AM | #19 |
Rep 7,377
its not about selling something. Its more about giving advices and avoiding throwing 15K in the toilet because of a tune that cannot control timings
Minor knock events over time was most likely what caused Sevak engine failure and yes when you get the Glow ignition code is already to late, at least for it was for me. Just run max map 7 on JB3 if you care about your engine.
12-10-2010, 05:22 AM | #20 |
Rep 5,689
Early on I had several glow ignition codes but have not had one in over a year.
I typically run map7-9 daily with meth and shell 93. Maybe I should turn it down to 7 full time.
12-10-2010, 06:50 AM | #21 |
Joint Chiefs of Staff
4927
Rep 116,037
On the JB4 alpha, the maximum boost target will always be 1/2psi less than the boost limit you set. So if you set the boost limit to 16psi then the target will never go above 15.5psi even if the map you are using is tuned for more. Glad to hear JB4 is running on pace even during alpha development.
Mike |
12-10-2010, 07:03 AM | #22 |
Rep 5,780
I would certainly trying testing your self and not rely on anyone's word. You have already stated to rely on Terry but also suggest you always test on your own. If so, you would have witnessed an increases in DME timing cirrections; i.e. knock retard. In my testing, which all data was supplied for analysis, there was at least 2x the amount of corrections with the JB versus the PROcede.
