Need Help! - Remove Rear Seat Back
09-19-2005, 02:47 PM | #1 |
Rep 57
Guys,
Need to get access to the MOST distribution block. Anyone here do the CD changer install or the Satellite Radio Install? How do I remove the Rear Seat Back? My car DOES NOT have fold down seats. Thanks in Advance, Sam |
09-20-2005, 02:41 AM | #2 | |
Rep 1,002
First: Take out the rear seat lower part (just pull hard at the front seam(upwards) and it pops loose and can be taken out) second: unscrew the bolts at the lower end of the rear seat back that hold the seat. They are Torx heads of either 40 or 50 size (T40 or T50) Third: climb in the boot with a screwdriver facing upwards to the parcel shell. Find the (almost hidden) unlocking holes (one left, one right) for the rear seats (just a hole on the metal with a lever behind them) and move the lever outwards to unlock the rear seat back. Itīs a so called emergency release latch (donīt ask me why itīs called that since there still are the bolts at the lower part of the seat). That release latch is really hard to find and even after youīve found it itīs really hard to figure out what to move where, but once youīve done it, itīs easy.
No, not THAT kind of tierfreund!
10-27-2005, 07:55 PM | #5 |
Rep 91
Is it easy to replace the seat bottom once it is removed? Does it just 'snap' back into position? I need to get under the seat bottom but am nervous about removing it.
E90 330i Ti Grey Burl/ZSP/ZPP/Navi/PDC Manual
10-28-2005, 12:44 AM | #6 | |
Rep 1,002
Btw, why do you need to get under there ? Thereīs nothing of interest beneath it and no space to mount anything.
10-28-2005, 01:19 AM | #7 |
Rep 91
Much to my dismay, my daughter threw up in the back seat. . It wasn't very much, and I was able to clean it all up, except for some that went under the seat.
Glad you asked?
12-06-2005, 06:38 PM | #9 | |
Rep 876
12-06-2005, 06:50 PM | #10 |
Rep 3,566
Drives: F30 M-Sport 328i Estoril Blue
Great advice Tierfreund and well done actionj and CA330 for a job well done. It does seem to be an easy thing to do but I just hope I never need to do it anyway as easy as it seems to be. Brave fellows, even though it was necessary to be done, no question.
Thing is, once you have done it, it's easy (that's the wisdom of hindsight) but till then.... Cheers people.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
01-14-2006, 06:29 PM | #11 |
Rep 2,059
Thanks Mr. Animal friend (just joking)! Your knowledge is well respected here at E90Post Tierfreund!
330i 6MT l 255 HP @ 5900 rpm 214 lb-ft Torque @ 3500 rpm l Alpine White l Beige l Aluminum l ZSP l 494 l PDC
"Freude am Fahren" = "Joy to Drive" |
06-01-2006, 11:51 PM | #12 | |
Got Seoul?
116
Rep 2,862
Drives: 2012 535i MSport
Can you say Alooooha?
[SIGPIC][/SIGPIC] |
08-31-2006, 09:21 AM | #13 | |
Rep 6,563
11-21-2006, 11:09 AM | #14 |
E60
43
Rep 587
speaking of throwup. friends 23 b-day down at the jersey shore. kid pukes captin morgan alll over with the windows down goin 110 on the garden state parkway. car was 2 weeks old. you can imagine my feelings. anyways 2 weeks and $800 later it was better than the day i picked it up from BMW. the guy told me he had to use a tooth brush on the celing and a tooth pick to get the puke out of the buttons on the radio. groseeee!
p.s. no smell! haha theres hope for all situations because mine was the worst! joey |
11-21-2006, 11:18 AM | #15 | |
Rep 6,563
under construction! |
02-26-2007, 11:46 PM | #16 |
Chief Warrant Officer 4
53
Rep 726
Drives: 335I, E46 M3, X5M
Heres a question for you guys... Is it possible to replace the rear seats in the sedan with the seats in the coupe??
03-19-2007, 05:40 PM | #17 |
Rep 10
Help
"Third: climb in the boot with a screwdriver facing upwards to the parcel shell. Find the (almost hidden) unlocking holes (one left, one right) for the rear seats (just a hole on the metal with a lever behind them) and move the lever outwards to unlock the rear seat back. Itīs a so called emergency release latch (donīt ask me why itīs called that since there still are the bolts at the lower part of the seat). That release latch is really hard to find and even after youīve found it itīs really hard to figure out what to move where, but once youīve done it, itīs easy."
I must be blind because I don't think I see these levers. I see two holes with a white plastic part behind them, and the plastic parts seem to move and have a spring tension on them, but they don't seem to be unlatching anything. Or am I looking at the wrong thing completely? This seems to make sense because they are in line with two metal posts that run forwards towards the seat backs. Also, I guess I should double check that there are only two torx bolts that hold the seatback on. There are 7 total I think but all but those two seem to only be anchor points for the seat belts. |
03-20-2007, 07:41 AM | #18 | |
Rep 6,563
Also, yes, there is only 2 torx screws (lower middle of seatback. gl
03-20-2007, 08:25 AM | #19 |
Rep 10
Hrm... I must have been looking at the wrong things. The white "levers" were only about 1" square and were not difficult to move (I could reach in with a finger and move them pretty easily).
Thanks for the help, I'll have to look some more. I've got to take it to the dealer for the 1st reprogram in satellite installation, maybe they will be kind enough to show me where it is (and not charge me an hours labor for it). |
03-20-2007, 09:55 AM | #20 |
Rep 6,563
is this what you are looking at from the trunk up at the upper parcel shelf?
if so, where is the white clip you are talking about. btw, dont remove those 2 screws or you will be somewhat sorry you did. coz it a pain to put it back (just trust me on that). could be that i dont know what i am doing but I been there so i thought i warn yall. I think the right way to remove the seat is to release the lever located somewhere in the general area of my photo.
03-20-2007, 10:35 AM | #21 |
pull my finger to get your kinderŪ surprise
148
Rep 10,455
^ tex, you know you're gonna get a LOT of PMs from me come summer when I take apart my car right?
so helpful with the pics
03-20-2007, 11:15 AM | #22 |
Rep 6,563
bookmarks and favorites is your friends...
