Procede v5 7DCT shift/safety logic
01-14-2011, 12:51 AM | #1 |
1750
Rep 17,960
Drives: A Lot
Hi guys
We've been working on this for a while. One of the problems we noticed when adding more torque to a 7DCT equipped car (either n54 or n55) is that the extra midrange torque can result in clutch slipping during full-throttle automatic downshifts. Depending on clutch/trans oil temp, this slippage can last a second or two where you notice the revs just float high without any vehicle acceleration. If it gets bad enough, an overtemp warning will appear on the dash sending the transmission in to a temporary safety mode were it wont even down/upshift for a few seconds. So we added some logic that detects automatic downshifts and triggers a low boost mode until the clutch is fully engaged. Once engaged firmly, the Procede quickly transitions to full boost. Works like a charm. Downshifts are quick, slip-free and car takes off like a rocket. (Similarly, the Procede will trigger a low power/boost mode if it detects transmission slippage in the middle of a pull.) Below is demo video demo on our n55 DCT. Boost (0-20psi) is represented in the gas level gauge. Car is in regular D mode. For the first two pulls, all I did was stop on the gas and let the Procede+transmission control unit do the rest. On the third run, I tried to confuse the two by going 1/2 throttle to trigger a primary downshift and then quickly full throttle to trigger a secondary downshift before the primary downsnift was complete. Didn't miss a beat. This feature has just been ported over to the n54 firmware but we still need to do some final testing. Anyone in the SF bay area have a n54 DCT car? |
01-14-2011, 08:13 AM | #2 |
Rep 1,480
Drives: '11 M3 MW/FR - '12 M3 FO/SC
Garage List 2004 Honda Hornet [0.00]
2003 Chevrolet 2500 ... [0.00] 2011 BMW S1000RR [0.00] 2011 BMW E92 M3 [0.00] 2012 BMW E92 M3 [0.00] |
I applaud your excellent work! Although I have a 6MT car
01-14-2011, 09:37 AM | #3 |
Rep 1,352
Drives: 2018 M3 CS
So when will the new v5 N55 DCT maps be available?
EDIT: I see they are posted on the Procede website. Updating today!
2018 M3 CS F80 l SMB l EXEC
2020 X5 M50i G05 l MW l BLACK l PREM l DHP l 22” l PARK l EXT S-LINE l LASER l TH l AG Last edited by TN_3; 01-14-2011 at 11:02 AM.. |
01-14-2011, 11:22 AM | #4 | |
1750
Rep 17,960
Drives: A Lot
Shiv |
01-14-2011, 11:23 AM | #5 | |
1750
Rep 17,960
Drives: A Lot
Enjoy! |
01-14-2011, 11:26 AM | #6 | |
Rep 1,352
Drives: 2018 M3 CS
(This) Download v5 User Software: Turn on your engine. Idle on Map1 for at least 5 seconds. Turn off engine. Turn ignition power ON. You will now this by looking at your fuel level gauge (it should show a reading). With your laptop plugged into an AC socket, update to the new n54 firmware (pro5v101.bin). Make sure the Procede resets itself after the update process is complete. Turn ignition full OFF and remove key (no dash lights) Insert key and turn ignition fully ON. Upload new map (11-25). Clear DME codes (you may see several codes that were triggered during the firmware update process.) And they cannot be cleared until you cycle off/on your ignition power as described in the previous step.
2020 X5 M50i G05 l MW l BLACK l PREM l DHP l 22” l PARK l EXT S-LINE l LASER l TH l AG |
01-14-2011, 11:43 AM | #7 | |
Rep 4,784
ERnie
2016 BSM/f80/ZCP |
01-14-2011, 11:59 AM | #8 |
1750
Rep 17,960
Drives: A Lot
01-14-2011, 12:00 PM | #9 | |
1750
Rep 17,960
Drives: A Lot
Shiv |
01-14-2011, 02:04 PM | #10 |
Rep 4,784
I hav a 6at butive been running the 7dct maps.
ERnie
2016 BSM/f80/ZCP |
01-14-2011, 02:06 PM | #11 |
1750
Rep 17,960
Drives: A Lot
01-14-2011, 02:24 PM | #13 | |
Rep 4,784
Hopefully the track dries up so we can run tonight.
ERnie
2016 BSM/f80/ZCP |
01-14-2011, 02:26 PM | #14 |
1750
Rep 17,960
Drives: A Lot
See post #6
01-14-2011, 03:36 PM | #17 |
1750
Rep 17,960
Drives: A Lot
I actually talked to them a few months ago after my clutch started to slip (it stopped slipping after a few days of casual driving). They already have an upgrade. Definitely considering it.
01-14-2011, 03:44 PM | #18 | |
Rep 441
hi Shiv, Are there any re-enforced parts available for our AT guys??? especially i'm going with RB turbos in the near future.... |
01-14-2011, 03:59 PM | #19 |
1750
Rep 17,960
Drives: A Lot
01-14-2011, 04:01 PM | #20 |
1750
Rep 17,960
Drives: A Lot
Here's a funny/sad out-take from two nights ago when i was doing another demo video of this DCT feature. I just happened to run over a grotesque pothole and slice a 2 inch long hole in my front passenger side tire. All captured on video :/
01-14-2011, 04:01 PM | #21 |
Rep 4,784
Upgrade your drive shafts, those are the first to go lol.
ERnie
2016 BSM/f80/ZCP |
01-14-2011, 04:34 PM | #22 |
Rep 2,291
I've had that happen to me before and had the same reaction. I hope you charge the tire to the city. Potholes drive me crazy.
