VBOX Numbers on 14.5psi with New Procede maps
01-16-2011, 05:55 AM | #1 |
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
Here is a run that I did last night. I couldn't reach 130mph as my max was 125.6mph before having to slow down. What do you think?
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
01-16-2011, 06:09 AM | #2 |
Rep 7,377
You should do pulls from 60-130 mph. 0 to are worthless. There is much more to compaire from 60 since thats what everybody uses.
01-16-2011, 06:10 AM | #3 |
Rep 2,663
I got close to 130 but couldn't cause of the road I was in. I'll do more testing tomorrow.
01-16-2011, 07:54 AM | #4 |
829
Rep 3,982
Although you have a good 0-60 time of 4.5 seconds, showing a decent launch, your 0-100 time should probably be quicker than 11 seconds.
How do your tires compare to the stock runflats? On the stock RFTs, full weight my JBD 335d does: 0-60 4.6 seconds, 0-100 11.4 seconds On stock RFTs, full weight, 91 oct. JB4/DCI, my 335 does: 0-60 4.4 seconds, 0-100: 10.4 seconds. Stock, I get around 12.5 seconds 0-100. Here are the 3 screen shots: JBD/JB4/Stock Ah...nevermind...you have a IX, that is about as heavy as my diesel, LOL.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
01-16-2011, 09:59 AM | #6 |
Rep 7,377
can you post your times 60 to whatever you came up in speed? You can do it through the software . Basically i mean something like this or look at Mr.5 as well:
01-16-2011, 11:19 AM | #7 |
1750
Rep 17,960
Drives: A Lot
Maybe we should wait until the maps are done and publicly released first?
01-16-2011, 01:53 PM | #8 | ||
Rep 2,663
Please let me know where to d/l the software. Thanks
01-16-2011, 02:05 PM | #9 |
Modder Raider
760
Rep 8,633
Drives: M3
Remember too that Hotrod really is out of the norm when it comes to performance.
I've stopped comparing his times a while back lol. Here is the Racelogic software... http://www.performancebox.co.uk/dlsoftware.html
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
01-23-2011, 03:08 AM | #10 |
Rep 2,663
Here's my new results
01-23-2011, 03:18 AM | #11 |
Rep 2,663
Notice the difference running the same amount of boost:
0-10 = .3s faster 0-20 = .2s faster 0-30 = .2s faster 0-40 = unchanged 0-50 = unchanged 0-60 = unchanged 0-70 = .2s faster 0-80 = .3s faster 0-90 = .5s faster 0-100= 1.1s faster So these maps definite improved the 0-30mph and 70-100mph. Shiv, is there a way to improve the 30-70mph?
01-23-2011, 05:08 AM | #12 |
Rep 7,377
Yeah there is an easy way. Get an ic and dps... Also you can set up in the box to show predefined times. Set for example 60-90 and 60-130 so that those are displayed in the vbox screen
Use then those 2 only to see how fast the car is. 0 to times are useless as there are too many variable involed and its not good for the car anyway. When you start seeing constant results over and over you have reached your car limits depending on the mods. Last edited by enrita; 01-23-2011 at 05:29 AM.. |
01-23-2011, 08:16 AM | #13 | |
Rep 2,291
01-23-2011, 12:29 PM | #14 |
829
Rep 3,982
Nice to see that you got it worked out.
Interestingly enough, your initial 4.5 sec 0-60mph and 11.0 0-100mph were identical to my 335d numbers from this morning. 66F temps. And I am only trapping 108mph. So I think its safe to say you were running far from optimum during the initial test results.
01-23-2011, 02:29 PM | #15 | |||
Rep 2,663
What tune are you running and what boost?
01-23-2011, 03:04 PM | #16 | |
829
Rep 3,982
On the diesel I am just running the JBD. Fuel enhancement only. Doesn't touch boost. I am hoping to run a 12.8 and break the diesel record next month! On a side note...averaged 43.5mpg back from the Laker game last Friday!
