Does anyone get a ticking noise from one exhaust when idling cold on their 335i?
01-16-2011, 06:12 AM | #1 |
Rep 2,042
I seem to be getting a metallic tinkling noise on cold starts from the left pipe on my e89 35i. It goes away completely when the car is warmed up. I don't think it's a leak because the sound disappears also when any sort of throttle is applied when parked. Anything to be concerned about?
NB: this isnt coming from the engine, only the left exhaust once the flap opens in the right side exhaust pipe. Last edited by Alext; 01-16-2011 at 06:18 AM.. |
01-16-2011, 07:42 AM | #5 |
Rep 2,320
maybe sometimes didnt noticed very careful...need double check if u post video would be better
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
01-17-2011, 06:46 AM | #10 |
Rep 1,302
Drives: AW 528 xdrive (AW 335i coupe s
I had that , took it to BMW and they replaced the exhaust .
M-tech front and rear bumpers /M3 style side skirts/gloss black painted roof/ black window trim/Matt black grill/35%tints/4"dimisaTips/CF splitters/M3 style trunk spoiler/VMR V70s/JB4/BMS dci/AMS FMIC/H&R sport with BMW performance shocks.
Thanx Sal and he's crew@AutoCoutureMotoring |
01-17-2011, 05:41 PM | #12 |
Rep 1,035
You need a new driver side muffler. Its the flap inside the muffler causing the rattle. They are known to fail and rattle, its very very common.
01-17-2011, 08:56 PM | #17 |
Rep 4,732
Muffler area? It is most likely coming from the turbo - downpipe connection; thats where wastegate rattle occurs. Maybe you have an exhaust leak?
01-17-2011, 09:31 PM | #18 |
I even mod my cereal
249
Rep 3,445
Drives: 11 ZCP DCT M3 14 328d 21 GT4
I'm getting rattling in my 335 from the driver's side muffler when it's slightly warmed up at idle. I have the golf tee mod done, but that shouldn't cause a rattle. Was there before I did the golf tee mod. Is it worth taking to the dealer? Off course I can take the golf tee mod out beforehand.
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser, Neodyme GT3 Wheel Color |
01-17-2011, 10:47 PM | #19 |
Rep 2,042
Well thanks for the input but I doubt its the wastegate rattle. Car is brand new 2011 model with <1000 miles for starters and its more like a ticking than a rattle. I will have a check for leaks, but seems strange it dissapears with any minor throttle.
01-18-2011, 03:48 AM | #20 |
Rep 2,042
Ok i put the car on ramps and checked underneath. I found the cause. It is the actual sheet metal of the muffler belly that is resonating at a specific frequency (RPM) at idle. I discovered it ONLY happens when the air con is on. It lessens as the muffler material warms up hence why after a drive it totally disappears.
When I place my hands on the underside of the muffler and apply pressure it absorbs the resonance and the noise ceases. There is nothing I can really do about and it isnt any cause for concern in any case. I can see though that the stock system does appear to have some restrictive bends along its length. |
01-18-2011, 08:25 AM | #21 |
Rep 1,690
I have it as well but it goes away after the car revs down after being started. I have the golf tee mod as well, but I highly doubt that is the cause. And like Alext said it's a ticking not a rattle. It's been there since I bought the car and I've reported it to the dealership everytime I bring it in for service and each dealership (I have used two different dealerships for service) say that it is normal.
