FS: JL Audio 300/2 Amplifier *Brand New*
01-16-2011, 09:26 AM | #1 |
Rep 1,608
I have a JL Audio 300/2 Amplifier that I was going to use for a stereo upgrade for an E90 LCI and no longer need it. The amp has never been used. This is a perfect amp to upgrade the subs under the seats Asking $200 shipped or OBO. Specs: * Rated Power: 150 W RMS @ 1.5 ohm-4 ohm (11V-14.5V) * Rated Power (bridged): 300 W RMS x 1 @ 3 ohm-8 ohm(11V-14.5V) * THD at Rated Power: <0.03% @ 4 ohm * S/N Ratio*: >108.5dB below rated power * Frequency Response: 5 Hz - 30 KHz (+0, -1dB) * Damping Factor: >200 @ 4 ohm per. ch./50 Hz * Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS * Dimensions: 13.4"L x 9.25"W x 2.36"H * Differential-Balanced Input Topology: (1 pair of inputs) * On-board Crossover: fully-variable (50Hz-5 KHz), selectable-slope LP or HP (12 or 24 dB per octave) * Preamp Output: 2-channel (full-range, LP or HP) * Speaker output connections: accept up to 8ga. wire * +12V and Ground connections: accept up to 4ga. Wire |
