What numbers should i be getting with these mods?
01-20-2011, 11:12 AM | #1 |
Rep 2,384
What type of dyno numbers do you think i would be getting with these mods?
I know i should just go and dyno it, im just curious what my hp and tq would be roughly.. Its a 2009 e90 335i, mods include: K&N Drop In Filter Active Autowerke Catless Downpipes What do you think? Last edited by alexc93; 01-27-2011 at 09:28 PM.. |
01-20-2011, 11:38 AM | #4 |
Rep 6,631
You're not getting 390whp out of a tune, DCI and DPs. 360-370 is more like it and that's being optimistic. Also take into consideration your real-world performance will be nowhere near the advertised numbers due to heatsoak on a sustained run from the stock FMIC.
E90 LCI N54 6AT
01-20-2011, 11:43 AM | #5 |
Rep 469
Drives: BMW 16' M3
On the dyno I use, maybe 340-350whp.
01-20-2011, 11:46 AM | #6 |
Rep 2,320
v5 only claims :Typical gains on an otherwise stock n54 powered BMW running on 91-93 octane fuel are 70-80 wheel horsepower and 80-90ft-lbs of torque.
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
01-20-2011, 03:59 PM | #8 |
Rep 6,604
Drives: e92 335i
around 400
01-20-2011, 04:26 PM | #10 |
Rep 2,320
01-20-2011, 06:12 PM | #13 |
Rep 4,732
01-20-2011, 06:46 PM | #15 |
Rep 3,460
knock is something that happens on cars that want to run 13 down to 10 up to 13 degrees of timing, but lower timing due to repeated knock. Real tunes have a way to change/alter timing.
Log timing and see for yourself. Being that you dont have any form of actual timing control provided with the tune, if your timing is below 9-10 degrees while floored at any point, you knocked. |
01-20-2011, 06:50 PM | #16 | |
Rep 4,936
Yep, You wanna be 10 or higher during full WOT sustained!. If timing drops quickly it knocks then it sends a signal to the ECU witch in turn pulls timing witch follows by a huge loss of HP. Methanol helps alot in preventing this.
[SIGPIC][/SIGPIC]
01-20-2011, 07:14 PM | #18 |
Rep 2,799
Nick, was that on 91?
thanks to MGallop |
01-20-2011, 07:42 PM | #19 | |
Rep 2,384
How am i supposed to get rid of knock then? |
01-20-2011, 08:02 PM | #21 |
Rep 3,460
01-20-2011, 08:31 PM | #22 |
Rep 6,631
So you are saying the Procede is a "real tune" with CPS offset?
E90 LCI N54 6AT
