OEM factory alarm on 335Ci audible?
02-20-2007, 03:56 PM | #1 |
Rep 2,377
Drives: Perfomance Model 3
i read from another member:
Only issue I had is when I had the OEM alarm installed. I wanted to have an audible sound when I lock my doors, not just the flash lights (just my personal preference). They installed the alarm, but the software does not play well, so they said to bring in back later in the year. is this still an issue?? also, anyone have issues with CA and OEM alarm? still have to use keyfob to engage i assume? keyless to disengage, right?
'18 Tesla Perfomance Model 3 White on White Performance Upgrade Pkg & EAP
*RETIRED* 2015 435xi GC [f36] | 2012 335i [f30] | 2009 z4 35i [e89] | 2007 335i coupe [e92] | 2001 325Ci [e46] *RETIRED* |
02-20-2007, 05:03 PM | #3 |
Rep 2,377
so you must use the keyfob to engage with comfort access (CA)?
but you do NOT have to use the keyfob to disengage when approaching the car? is this correct?
02-20-2007, 05:17 PM | #4 |
274
Rep 6,510
everything works exactly as it did before the alarm was installed... when you grab the handle, CA unlocks the car and disarms the alarm at the same time(chirp chirp), and then when you leave, it locks and arms the alarm (chirp) at the same time.
02-21-2007, 11:51 AM | #5 |
Rep 159
I am guessing that you do not have the acoustic confirmation set on.
with iDrive configure: hazard flashers light: locking/unlocking Acoustic confirm: locking/unlocking without iDrive, use turn indicator stalk up/down button to find KEY symbol appears. Then set hazard flashers light and Acoustic confirm options.
Alan(iX)
1988 BMW E30 325iX Ordered 6/29/2006, Built 9/6/2006, Delivered 9/29/2006: 2007 BMW E92 335i Coupe, 6MT, space grey, black leather, dark burl, CWP, ZPP, ZSP, Comfort Access, Nav, Power Rear Sun Shade, Park Distance Control, Sirius |
02-21-2007, 12:46 PM | #7 |
Rep 2,134
I planned on getting the alarm but wanted to wait until the dealerships work on a few. Been reading too many horror stories. Good to hear a good news story on the alarms.
2007 E92 335i Coupe: Monaco Blue/Premium/Sports/Winter Package/Nav/CA/6MT/TT/Active Cruise/Active Steering/iPod/Rear Shade/Tint/Short Shifter/OEM Alum Pedals//
03-26-2007, 08:11 PM | #8 |
unstratified
Rep 162
Horror stories? I had the OEM alarm installed last week, and I've brought the car back for reprogramming, as it didn't add the acoustic confim. when locking & unlocking options (panic function doesn't work either). The siren does chirp once for arm and twice for disarm, but I'd like to have the ability to silence it from time to time (coming home late, for example). So my service writer calls and tells me that the audible confirm. options were removed mid production, and my car fell on "the wrong side of the VIN break". (built early last month) This sounds like to me. I called BMWNA Customer Relations for kicks, but he couldn't find anything to corroborate, though he did conceed that the explanation doesn't make much sense.
Has anyone out there heard anything like this? |
07-05-2007, 07:56 PM | #10 |
unstratified
Rep 162
All is well
For the record, my alarm programming issues were eventually resolved (third time's the charm!)
It took a PuMA case with a provided update file to finally do the trick. To review: Dealer installs OEM alarm After picking up car, notice acoustic confirm. options not present and panic mode inoperable, also LED flashes rapidly on arming (as if "faulting out" a zone)Describe above symptoms to SA, also request Progman v.25 for popup nav arrows (unaware at this point that it breaks RTTI) Am told Program update was successful, but acoustic confirm. & panic features were discontinued mid-production and mine "fell on the wrong side of the VIN break". Also rapid LED flashing on arming is "normal".Demonstrate faulty hood switch to tech, gently suggest that a PuMA case might be a good idea Pick up car with acoustic confirm. options, panic mode, hood switch and RTTI all fully functional!To alliteratively state the obvious moral: Polite persistence pays |
07-06-2007, 09:04 AM | #11 |
Retired
19
Rep 868
Drives: Z4 s30i
Piezo,
I am in a similar situation. Three visits already and still does not work correctly. I am persistent but getting very annoyed. V26 solved several issues like the fast flashing but the motion sesnors still do not work in my E93 top up or down !!
M3 GTR - 1/5 scale - 4.2 HP w/ Collari hydraulic brakes - would you believe ~80 MPH on straightaway !! |
07-06-2007, 03:04 PM | #12 |
unstratified
Rep 162
msimon18, I've sent you my PuMA case# in a PM; perhaps your tech might find something helpful by referring to it
As for the interior motion sensor, mine has worked all along. Where do they install that on an E93? I'm guessing not the headliner. |
