Voice Control
09-23-2005, 05:24 AM | #1 |
Wk 26 E92 335i Tiag, saddle, nav,sports,premium,CA
10
Rep 59
Voice Control
I cannot wait to use the voice command feature but my question is....what is the accuracy rate of the system in recognising voices???
Is there a training procedure or is it a matter of speaking clearly and SLOWLY??? I dont want to command the radio to tune into a particular frequency if it takes 5 seconds in slowly commanding....would be quicker by hand using idrive !! |
09-23-2005, 06:46 AM | #2 |
Rep 84
Just speak clearly. No training required - regognises anybody's voice.
I've had my car for a couple of weeks and have used voice commands loads of times and had no problems with it.
Bimmer325i
------------------------------------------------------- 325iSE, Sparkling Graphite, Black Leather, iDrive Pro + Voice Control, Logic 7, Xenon, 18" Wheels, Sports Steering Wheel & Seats, PDC F&R Deposit placed for E90 M3. |
09-23-2005, 06:55 AM | #3 |
Rep 3,566
Drives: F30 M-Sport 328i Estoril Blue
try it our a few times. you will get the hang of it. it's not hard at all.
what's the worst that could happen? so the voice lady gets angry with you and refuses to let you start the car. only joking!!! check out CMD's well laid out voice prompts list a little further down the threads list. that will really help you get going and keep you going. enjoy your car.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
09-23-2005, 06:57 AM | #4 |
Rep 12,276
Couple of tips: speak normally (we tend to over inunciate) at a normal speaking volume. Make sure all windows are closed and the A/C isn't running on loud fan - background noise makes it difficult. Certain words are just difficult to recognize... for example, words with soft low sounds like "home" are tough. I ended up changing it to "house", which is a clearer.
Experiment a little when you get it. I will say, it is a very good VR system.
I think it is bad luck to be superstitious |
09-25-2005, 10:52 AM | #6 |
Commander in Chief
37
Rep 1,034
I think the voice control works GREAT! I have had only a few instances where it didn't immediately recognize the command. But, in general I can speak at a normal conversation pace and it works fine.
I have even used these commands when I was hoarse and it still worked fine. There are two things that will cause it to malfunction. 1. If you start speaking before the beep. This is probably the most common problem I have had. 2. A few times my radar beeped while I was talking and caused it to give the wrong command. Basically, you need things to be quiet in order for it to hear your voice. Michael
2008 BMW 535i Space Gray, Black Leather, Dark Bamboo Trim| Sport Automatic with Paddles | Sport Package
2008 BMW M5 (gone, but not forgotten) Space Gray, Silverstone Merino Leather, Madeira Walnut Wood Trim | 7speed SMG | All options Mods: Corsa Exhaust | RPI Ram Air Intake | H&R Sport Springs | Rogue Engineering 12mm spacers |
