How to determine if you are Sat Prep'd?
02-05-2011, 08:10 PM | #1 |
Rep 5
I have a 2006 325Xi that I bought used. I thought it was sat prep'd but I checked the trunk area and I do not see any connectors for the sat receiver at all. Any way to really check?
Thanks, Jim |
02-06-2011, 01:30 AM | #2 |
Rep 745
Take you VIN to the local dealer (ask someone in the parts department) and they should be able to give you a printout showing all the options your car came with.
Although if you did not see the unused wrapped-up cable bundle (aerial and MOST connector) to the left of your bluetooth and ULF modules, then it is likely you don't have this option. If that's the case, it is always possible to retrofit it: http://www.e90post.com/forums/showthread.php?t=10536 |
