PROcede DIC Dyno
02-13-2011, 09:45 PM | #1 |
Rep 1,262
PROcede DIC Dyno
Did my first dyno today, with the new 02/07 maps.
Base (stock boost in valet mode): 259HP 287FT*LBF DIC #'s (14PSI): 332HP 384FT*LBF Overall I'm pleased, with 15% drivetrain loss, at the flywheel that converts to: Base (stock boost): 305HP 338FT*LBF DIC (14 PSI): 390HP 452FT*LBF Details: 2007 335i 6MT, only mod is the PROcede 49k Miles, Procede installed at 44k Ambient conditions: 86*F, 5% humidity Fan placed at the front was weaksauce, barely any airflow at all...
Josh-
Last edited by Transport3r; 02-13-2011 at 11:46 PM.. Reason: Replaced plot with higher quality scan |
02-13-2011, 09:55 PM | #4 |
Rep 6,631
Awesome! Look at that curve to redline... puts any doubts to rest about Shiv's dyno results. I would still prefer a richer AFR at the low RPMs though.
+71whp delta. Thanks for posting a damn stock boost baseline unlike all these other glory results we see around here.
E90 LCI N54 6AT
02-13-2011, 10:10 PM | #6 |
Rep 1,708
when i logged the last maps AFR was a consistent 12:1... this run is a lot richer. I wouldn't think there's a need for below 11:1
looks good though. what's the rpm scaling; when did you shut down? looks like around 6700 |
02-13-2011, 10:15 PM | #9 |
Rep 6,631
based on my own dyno results that measured off road speed, he wound it out to redline.
E90 LCI N54 6AT
02-13-2011, 10:19 PM | #11 |
Rep 1,708
02-13-2011, 10:23 PM | #12 |
Rep 6,631
compare the OP's power curve to my V4 dyno on meth. As you can clearly see, this map revamps the power curve so that you are sustaining power to redline instead of having to short shift for maximum power.
http://www.e90post.com/forums/showthread.php?t=436001
E90 LCI N54 6AT
02-13-2011, 10:24 PM | #13 | ||
Rep 1,262
Thanks guys! She felt real strong on the drive there!
Wouldnt knock show more wavyness in the torque curve? And wouldn't the Procede cut the timing when it knocks? Also, see below. It was map 2, but instead of 14.5 PSI, I set it to 14 PSI. That's what my car always autotuned to on V4 (similar temperatures)
Josh-
02-13-2011, 10:25 PM | #14 |
Rep 13
Thanks for sharing your results.
I noticed your baseline is much lower power than I've seen on other dyno charts. I presume that is with the tuning installed but in a stock like mode? Is the tuning itself lowering your baseline? The air/fuel ratio looks richer than I have seen for untuned cars. Also I can't help but notice how wavy the curve is given the scaling. Does this mean the car was knocking? If so is there an adjustment you need to/can make now as result of this testing to improve the results next time? |
02-13-2011, 10:38 PM | #15 | |
Rep 949
The numbers on the base run are fine. Every dyno reads differently. I have been on dynos that show my stock numbers as 226 and dynos that show my stock numbers as 265 (and everything in between). Even different dynos on the same day. Dynos show you deltas - because all will have different baselines. As for what to do - I personally don't run over 13-13.5 psi on stock car. With DCI and my meth off I will run 13ish. The dyno looks pretty good though. Like I said - and this is PURE opinion - if you really are that stock I would run less boost. 12.5-13psi just because you dont have DCI. Enjoy |
02-13-2011, 10:43 PM | #16 | ||
Rep 224
02-13-2011, 10:47 PM | #17 |
Rep 1,708
i shouldn't have even mentioned "knock". I am just curious to see the timing curve with DIC. at 14psi in 4th gear... if there's load on the dyno (don't know much about dynos), then there maybe some drop because "light knock"... just curious to see how DIC map looks in that situation.
02-13-2011, 10:54 PM | #21 |
Rep 224
