help ecu problem!
02-14-2011, 12:33 PM | #1 |
Rep 794
help ecu problem!
the large connector containing all of the sub connectors are completely stuck in the ecu! can't get them out i removed the clips that you pull out and there not moving! please help i need to get them loose to remove the jb3!
Gone But Not forgotten:
-07 Shelby GT500 W/ Full Bolt on E85 -08 335i 6MT W/ Full Bolt On E85/Meth -08 M3 DCT W/ Full Exhaust / Tune -13 B8 Audi S4 APR Stage 2+ |
02-14-2011, 12:44 PM | #2 |
Rep 2,875
How did you manage to get the locking clip out with the large connector still connected to the ecu?
Reason why I ask is that the locking clip on the large black connector is a two stage lock. So you have to have unlocked the large connector before pulling out that clip..... Make sense?
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
02-14-2011, 12:46 PM | #3 | |
Rep 794
02-14-2011, 12:56 PM | #5 |
Rep 2,875
So is the connector all the way on or just half way?
I'm sure you've already tried to wiggle it fairly hard to try to get that connector out, no?
02-14-2011, 06:06 PM | #8 |
Rep 794
will take pictures and show you guys..
02-14-2011, 06:28 PM | #9 |
Rep 794
sorr for that bad pics it is crazy cold outside but that thing as you can see the clip is out and it won't move!!
02-14-2011, 06:31 PM | #10 |
Rep 2,875
Try pushing it back in a little, wiggle it, and try to pull it out.....
02-14-2011, 07:09 PM | #12 |
Rep 502
[QUOTE=TheStig;8914419]sorr for that bad pics it is crazy cold outside but that thing as you can see the clip is out and it won't move!!QUOTE]
Are you saying the large ECU connector will not pull UP vertically or that the subconnectors will not slide out horizontally?? The large ECO connector should pull out vertically now that the clip is out. It is no big deal to remove the clip. I have done it many times. As for the subconnectors you need a small screwdriver to move the small tab on the subconnector to the side to slide it out. Put some lateral traction on the wire loom as you move the small tab to the side and it should slide out to the side. Watch Shiv's Procede install video to see what I mean. Watch from 1 min:37 sec and he describes it well. Good luck |
