Disappointed.
02-16-2011, 10:21 PM | #1 |
Cobb Stage 2+/ICarbon/HPF/Stett
40
Rep 488
Disappointed.
So I decided to run my e92 coupe at the track tonight. I am running PROcede V5 w/ the December map. My car is 6MT and I'm running 265 Nitto Invo tires on 19x10 rear wheels. Everything else concerning my drivetrain was stock.
On most of my runs my 60 ft timewas 2.5+ sec and the wheel hop was baaaaad. It sounded horrible. I just couldn't get traction down whatsoever. What can be done to alleviate this? How are most people launching their 6MT? Traction control was fully off for all runs. 93 octane. Most of my runs were low 14s with mph ~104. My best run was my second run on the evening. The numbers are below: 60ft: 2.2 1/4 mile et: 13.34 1/4 mile mph: 106.99 I have no idea why this run was so much better than the other runs. Was PROcede changing the degree of aggressiveness of the tune between runs? What can I do to bring my times down? I feel a little disappointed that with an extra 70+ horsepower I am running times that are close to stock mag times. What are all you 11sec guys doing to get power to the ground. I have a race slated with a buddy's Cayenne Turbo S (550hp) and my pops SL600 twin turbo in a couple weeks. No shot in hell with race gas? My ICarbon downpipes are being shipped out this week. TIA Last edited by 135i; 02-17-2011 at 12:23 AM.. |
02-16-2011, 10:24 PM | #2 |
Rep 465
way to big of a rim to get traction get some 17's with radial then you will hook good.
UR Catted Dp's - BMS DCI - JB3 2.0 - Helix FMIC - Vent Boost Gauge - CF Grill-DO Meth Kit 2-Carbon8 Power Dome Hood-Amuse Front Bumper-M3 Side Skirts-LC818 Smoke Chrome Wheels On The Way
02-16-2011, 10:28 PM | #3 |
Rep 4,771
For what it's worth, I ran a 12.9 with a street start (no launching) and the Procede V4. Your times should definitely be better...
That being said, I wouldn't worry too much. You're running a tune only so don't expect dramatic results. Also, 6MT is always hard to launch just right |
02-16-2011, 10:29 PM | #4 |
Rep 223
Practice, practice and more practice. The more seat time you have in the car the better you'll get at the strip.
2008 Sparking Graphite 335i 6MT Coupe - Single Turbo
2007 Montego Blue 335i 6AT Sedan |
02-16-2011, 10:36 PM | #5 | |
40
Rep 488
02-16-2011, 10:38 PM | #6 | |
Rep 1,271
OP- Do you have good tread left on your tires? Also, Are you revving high and just dumping the clutch? Your description sounds like this could have been your technique. Try playing around with revving up to 3-4k and letting the clutch out a little slower, but not too slow/not too fast. You will have to mess with your timing to get it right.
2007 335i Jet Black e92 6AT - VRSF Full street exhaust DP, Chargepipe 7.5 FMIC, MHD, XHP, Koni orange/Eibachs, some other stuff
2007 335i Jet Black e90 6MT - Eibachs, magnaflow exhaust, carbon hood, short shift kit, some other random stuff - being sold somewhere sometime soon probably 2010 335i AW e90 6 AT Msport - The GF took this one over... JB4, PE exhaust, Koni yellows/Eibachs, pink badges, fuzzy steering wheel cover ? |
02-16-2011, 10:45 PM | #7 | |
40
Rep 488
02-16-2011, 10:55 PM | #8 |
Rep 1,271
I shift around 6k. With my old tires and no tune, I would go sideways in 2nd. Now with my tune and new tires, I stick very well. So, what happens if you go into 1st slowly, then gas it? Do you still lose traction? What I'm getting at is: are you losing traction because you are launching too hard, or because your car has too much power and your tires are lacking grip? Doesn't the proceed have the ability to limit boost so you don't lose traction in 1st? Or did I read that somewhere incorrectly?
02-16-2011, 10:57 PM | #9 |
Rep 553
I could not get traction with a stock car above a 1200 RPM launch. Feather the clutch at a much lower RPM and feel what the tires are doing. I have heard with a tune that a 2nd gear launch is the way to go. Maybe someone can chime in about that. My V5 should be here Friday but I wont have time to put it in for a few weeks and would love to see what I run after that.
[SIZE="2"]335 E92 Space Gray/Coral/Aluminum/6MT
02-16-2011, 11:03 PM | #10 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
I dont know, I like my clutch more than a fast track time.
2015 - Cayman GTS - Stock
2011 - 335is e92 - Cobb PTF E40/Rob - Beck/AR/Helix (458 rwtq and 479 rwhp) - Retired 2007 - 911 Turbo - EP1/AMS (617 awtq and 500 awhp) - Retired 2008 - 335i e92 - Cobb/AR/Helix/OSS (384 rwtq and 356 rwhp) - Retired |
02-16-2011, 11:05 PM | #11 | |
40
Rep 488
So what I'm taking from this is perhaps launch in second and shift at 6000 rpm for the next go around? |
02-16-2011, 11:08 PM | #12 |
Rep 1,883
Wheel hop = very bad. Make sure to get off the gas if you start wheel hopping, unless you want to break something.
I've got my best 60' in my MT, by holding rpm around 3-3.5k and barely letting the clutch out until I felt the tires grab then letting it out about half way until around 5.5k then clutch fully engaged (pulled a 1.89 60' on RFTs on stock 18s with tune+DCI doing this). It really takes a lot of practice though. 2nd gear launch is typically done for the Autos, but you'll never get your best times that way. If you are pulling 2.5s then I'd be willing to bet that you are staying on the throttle too much while you are spinning. I can recover from blowing my tires off the line and still do better than a 2.5, but then again I have 100s of passes in this car. If you feel/hear the tires spinning get off the throttle and recover, then get back into it.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
02-16-2011, 11:10 PM | #13 |
Rep 1,883
Also, avoid the water box unless you are on drag radials or cheater slicks. Only do a quick burnout to clean your tires, none of that obnoxious shit that you see the motorcycles do. First gear you want to shift at redline, all other gears around 6500.
02-16-2011, 11:15 PM | #14 | |
40
Rep 488
Even launching lightly and then hammering it I would loose traction and have to let off. It was frustrating. |
02-16-2011, 11:26 PM | #15 | |
Rep 465
02-16-2011, 11:27 PM | #16 |
Rep 1,271
This is telling me its not so much in how you are launching then. More in the tires. I'm curious to know about the traction control in the tune.
02-16-2011, 11:35 PM | #17 |
40
Rep 488
I wasn't running the the piggy traction control at the time. I just would of thought my tires would of been better at hooking up. Bad tires? They have about 7k miles...
02-16-2011, 11:52 PM | #18 | |
Rep 1,271
02-17-2011, 12:01 AM | #19 | |
Rep 4,771
12.9 @ 111. Grandma start. Map 1. / thread jacking |
02-17-2011, 12:04 AM | #20 |
Rep 6,631
A properly driven car will run maybe 13.0@109-110 6MT tune only, pump gas on street tires. This is a difficult car to launch on street tires; go easy on the launch, say a 1500-1800 RPM launch on street tires and don't aggressively mash off the line, go 50%, easing in when you feel the rear end hooking. Put it in DTC mode as your training wheels to learn your limits. You could also short shift into 2nd gear and go WOT, conditions and traction permitting.
If all else fails, get some drag radials and let 'er rip!
E90 LCI N54 6AT
02-17-2011, 12:07 AM | #21 |
40
Rep 488
02-17-2011, 12:13 AM | #22 | |
40
Rep 488
