E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Flywheel chatter
Reply
      02-18-2011, 01:15 PM   #1
Sigma 3
Drives: A few things
Flywheel chatter
I have 50k on a bone stock 335. I have noticed what sounds like flywheel chatter shifting from 1-2, somtimes 2-3, and occasionaly at idle. I dont think its the throw out bearing as the sound that makes is different. Anybody have heard this before? The sound can best be decribed as a diesel engine. The shifts are at low speeds. TIA
In the land of the blind the man with one eye is King
      02-18-2011, 01:29 PM   #2
boostd92
Drives: '11 E92 M-Sport
Most likely wastegate rattle.
      02-18-2011, 03:57 PM   #3
Sigma 3
Ehh I would hope so ,but the sound is at its worse when engaging or dis engaging the clutch.
      02-19-2011, 10:24 AM   #4
E36graduate
E36graduate's Avatar
58
Drives: 2013 335i M-Sport 6MT
drive line slack, clutch chatter, etc....my e46 m3 did the same, sometimes very loud and was still running fine at 125,000 miles. Try this....start the car, take it out of gear and take your foot off the clutch and shut off the engine and see if you get that rattle as the engine stops. Now do the opposite and turn off the car with the clutch pedal pushed in...it should not be as loud, but it will tell you if the noise is clutch related. I believe my E90 has similar drive line noises as my m3, but not as loose and rattly.
2008 335xi - 6MT - BMS JB4 G5i - BMS DCI - BMS OCC - BMS WW Meth - Spec Stage 2+ - Spec SMFW - 19" MVR Magnum's - KW V1's - TMS 12.5+20mm Spacers
      02-19-2011, 10:25 AM   #5
Litos
Drives: 2012 Challenger RT Junk
^^^ great advice
      02-19-2011, 12:12 PM   #6
zsapphire7
zsapphire7's Avatar
Drives: 08 e92 M3
i get this noise too. Is it supposed to be normal? or could it mean a loose clutch?
      02-20-2011, 10:48 AM   #7
E36graduate
58
don't know if a clutch can be loose or not, however most of all my BMW's (m3 and 335) and Audi S4 had this clutch/flywheel type rattle, especially when you shut off the engine without the clutch engaged. I am told the slack in the drive line is engineered into the car. If you ever take off your shifter boot and all that insulation below it where you can see down to the ground...you will easily hear that slack. I chased down that rattle on my m3 for months and finally put all the insulation back and just lived with it.
      02-20-2011, 08:33 PM   #8
TedRoc
TedRoc's Avatar
Drives: 2021 M850i Gran Coupe
I had the same issue... I needed a new clutch and fly wheel.
2021 M850i Gran Coupe Mineral White
Sold Cars- 2018 M3 F80 ZCP Yas Marina / 2017 M3 F80 ZCP/ 2014 435i Sport Silver / 2009 335i E90 LCI AW / 2005 535i Silver / 2002 323ci Black Dinan Stage 3
      02-20-2011, 11:54 PM   #9
Sigma 3
I tried this and got no rattlle doing either one, But what sounded like a bad turbo or ac compressor
      02-21-2011, 04:12 AM   #10
ciomas
ciomas's Avatar
Poland
30
Drives: M4
need to try it today. BMW already tried replacing one of my bearings and it didnt help.
335 - Öhlins//Swift//M3 front suspension//M3 subframe bushes//Quaife LSD//AR Design Catless//Forge Intercooler//Alcon BBK//Goodridge//AFE//RPI//Fenders - SOLD
M4-Mineral Gray/Full Shakir Orange/DCT/M Ceramic/M Adaptive Susp.
      02-21-2011, 01:34 PM   #11
E36graduate
58
Sigma 3....can you make a sound clip ??? could be a heat shield on your exhaust?
      04-24-2011, 09:31 AM   #12
e9X
enthusiast
e9X's Avatar
Philippines
34
Drives: 2006 TiAg 330i sport package
My e90 330i 6 speed does this too.
Mostly noticeable during idle but it goes away when clutch is depressed.
They call it normal - the flywheel chatter.
I complained about it with the dealer and under the warranty they replaced my clutch.
Unfortunately, when i got the car back the rattle is there and it didn't make any difference whatsoever.
The car still runs good and so far I haven't had any problems with it in general.
I see a lot of people saying that this is normal on 6 speed manual cars...
Reply
e90post
