A DIC Datalog and questions
02-18-2011, 01:30 PM | #1 |
Rep 1,708
Below is a DIC 2-7 datalog.
What is the ign cor (maps) channel and how does it relate to typical IC? Also i noticed boost setpoint when off boost is now 0 instead of -0.7psi (I'm at about 700ft above sea level). What's the change? I little more info on Shiv's DIC would be great, as I expected to see some IC reduction in 3rd. Also I seem to remember other user logs showing more total IC at maybe 3 or 4deg at the same setting of 100% IC. Are there other determinants? Talking about bog in the other thread, this log seems a little different than past at shift... the retard not as late into the shift... but not sure on this one and have to look at more logs. |
02-18-2011, 01:41 PM | #2 |
Rep 6,631
Maybe bogfix not enabled? Maybe shiv can chime in. Timing should be reduced at the shift point.
On another note, no knock anywhere!
E90 LCI N54 6AT
02-18-2011, 02:29 PM | #3 | |
Rep 1,043
19 Audi RS5
15 Audi S5 GIAC Stage 2 white 11 E92 335is DCT FBO 441 whp silver 08 E92 335i FBO 6MT 427 whp space grey 05 E46 M3 red |
02-18-2011, 02:44 PM | #4 | |
Rep 1,708
no why do you ask?
Yes, no knock... but this is not new to procede. The maps do feel great... i was just expecting more reduction in IC with it being dynamic. |
02-18-2011, 02:50 PM | #5 | |
Rep 1,043
19 Audi RS5
02-18-2011, 03:02 PM | #6 |
Rep 1,708
02-18-2011, 03:28 PM | #7 |
Rep 4,771
02-21-2011, 11:30 AM | #9 | ||
1750
Rep 17,960
Drives: A Lot
Shiv |
02-21-2011, 11:53 AM | #11 | |
Rep 2,842
I can only see two possible data channels in the list that seem to apply: Ignition trim Ignition Total Correction Desired. Is it one of those? cause I have been using ignition correction (maps) as well. |
02-21-2011, 11:57 AM | #13 |
1750
Rep 17,960
Drives: A Lot
Ignition Correction (maps) represent the ignition correction induced by the static load x rpm table. It doesn't show additional corrections applied after that by the DIC system, bogfix, etc,. So if you want to see what is actually happening in there, log "Ignition Correction" instead. For the sake of clarity, we'll probably just eliminate the Ignition Correction (maps) channel with the next software update.
02-21-2011, 11:58 AM | #14 | |
Rep 2,842
