2011 335i bluetooth retrofit
02-24-2011, 04:13 PM | #1 |
Rep 1,038
Hello
I have a 2011 335i sedan. It terms of options it only has sport package, leather and folding rear seat. No navigation. Somehow I managed to decline the Bluetooth integration option when I was ordering the car, which I regret now. So, I'd like to add it now. I found this thread on this forum http://www.e90post.com/forums/showthread.php?t=85149 which was last updated in 2009. I wonder if there are any specifics for 2011 335i. I hope someone can help me to answer the following questions: 1) Is my car pre-wired for Bluetooth? I heard that all USA models come pre-wired, but still wonder if there are exceptions from that. 2) What parts will I need? 2) Where can I order the parts? `getbmwparts.com` (Tischer) doesn't seem to list the TCU part if I browse by year/model. Searching by part number gives a different part (84109181230 supersedes 84109171590) with a significantly different price ($382.38 vs $675). Is that the right TCU? 3) The light cluster in my car doesn't have the SOS button. It is just flat and solid in that area - no hole. As far as I understand, the SOS button assembly also holds the microphone. So, do I also need to order a different light cluster panel, so that it has a hole for the microphone/SOS button? 4) Does anyone know a dealer/service center in San Francisco Bay Area that has a clue when it comes to retrofitting Bluetooth to 335i? The local dealers are totally in the dark. DINAN in Mountain View at least understands what is meant by that, but it looks like it is the first time for them as well. I'm bringing the car over to them to take a look on Monday. Thanks in advance for any help. Last edited by AndreyT; 02-24-2011 at 05:16 PM.. |
02-25-2011, 08:14 PM | #2 |
Two turbos are better than one!
119
Rep 404
I have an 08 335XI which does not have bluetooth and I thought about the OEM bluetooth retrofit, but after some research, I am going in a different direction.
I have ordered a Parrot MKi9200, Parrot Unika for steering wheel integration and a quickconnect harness so I don't have to cut any wires. I have also ordered a proclip dock for my iphone 4. Advantages: Cheaper A2DP music streaming through bluetooth or hardwire, via Parrot You still get to use the steering wheel controls and Parrot unit will mute music when a call comes in. Just an alternative for you to think about. |
02-26-2011, 07:53 AM | #3 | |
Rep 13,023
There is no OEM pre-wiring for OEM Bluetooth retrofit in your MY2011. This has been discussed too many times, search for "Bluetooth Retrofit" and especially read the sticky at the top of this forum.
02-28-2011, 08:03 PM | #5 | |
Rep 1,038
BTW, does anyone know why DICE MediaBridge support for 3-series stops at MY2009? Is it just a normal R&D lag while the new car models are getting researched/supported/tested and finally added to the supported model list? Or is there some fundamental issue with 2010+ models that makes them incompatible with devices like DICE MediaBridge? |
02-28-2011, 09:21 PM | #6 |
Rep 743
CTUNIPAR005 - adapter
CTUNIBM02 - patch lead www.connects2.com With these 2 parts, this is all we need along with some DIY guidance. I have a 2011 335d, have not purchased the above, but thats what my research has found. Email connects2 to confirm part numbers. They ask you what sound system you have, I have BMW Professional Last edited by rogerdiaz; 03-01-2011 at 08:45 PM.. |
