Downpipes + stock exhaust = damaged 2nd cats?
02-27-2011, 12:39 PM | #1 |
Rep 842
Is it true that the 2nd cats aren't strong enough to clean emissions so therefore running catless downpipes with stock exhaust will destroy the 2nd cats?
I hate the smell of catless so I was thinking of running downpipes with the stock 2nd cats. Can you guys chime in? How many miles on the car w/ catless downpipes and stock 2nd cats? |
02-27-2011, 12:56 PM | #2 |
Rep 1,809
One thing I noticed is that after the demoval of the primary cats, the smell becomes very strong even with secondary cats in place, which means that the primary cats are the ones that do most of the emissions cleaning. So it doesn't matter if you run secondary cats or not, it will stink anyway. I am going to take them off very soon.
02-27-2011, 01:58 PM | #7 |
Made in Italy
31
Rep 287
Drives: Former 135i
I've original exhaust and catless downpipes with no-probs.
Initially, just upgraded (for the first 100-200miles), i've felt a little like-toast/popcorn-smell... But I think it's normal when u put on a new exhaust... |
02-27-2011, 02:24 PM | #10 |
Rep 177
I have AR catless DPs with stock secondary cats and exhaust.
I only noticed a slightly stronger exhaust smell compared to stock. The difference is not very noticeable at all. I have about 10,000 miles on the car since I installed the catless DPs.
2008 E90 335i | PROcede Rev 2.5 | PWM Meth | CP-E FMIC + OC | AR catless ceramic DP | BMS DCI | Wavetrac LSD | MORR MonoForged VS8.2 | Michelin PSS
02-27-2011, 03:57 PM | #11 |
Rep 657
I just installed some UR catless DP's and the first 20-30 miles smelled because of the PB blaster I used to get some bolts off. If there is a smell it is very minute.
/// E92 | JB4 | UR DP | BMS DCI | H&R | LC Z2S | |
