E92 M3 parts on a E92 335i
02-28-2011, 04:04 AM | #1 |
Rep 715
Hi guys
I have a question about the M3 and the 335i The complete M3 front suspension with hub crossover and everything , could it be put on a 335i ? Same question for the rear , the subframe that holds the differential , all arms , suspension and everything . Next has to do with cosmetics , I was thinking of changing my front . The hood and put on some splitters on bumper . But I have got a good deal on some used parts from M3 , so question is : what parts from M3 do I need to make the front M3? I heard from earlier somewhere that Hood , bumper , fenders and headlights where needed for the whole transformation. Later I checked with headlights , they have same parts number , so that is not a concern I guess. Also when I check on the online EKT parts page , that there was some difference in price and parts number for just the car chassi , M3 and 335i compared. Also , this is a european version car. The goal with these questions is to find out if I could upgrade my 335i with M3 parts and know if I have option to do the M3 conversion in front. And I consider building a track car , build it from scratch . Its way more afordable than buying one complete. I found all main components and price is not that scary . But I need to know if I can use the "normal" E92 chassis or if I need to get hold of a salvagable chassi from a real M3 to build the track car. Also , if possible if moddification of the "normal" E92 chassi is needed , how much work is it ? I tried to look here for previous threads about this , but didnt find much. But that does not mean they dont exist... |
02-28-2011, 04:08 AM | #2 |
Rep 7,377
you are better off searching on the suspension section. Lots of info there.
