GIAC stage II flash...
03-16-2011, 09:02 PM | #1 |
Rep 838
I will be getting the GIAC stage II flash installed next week but curious if the software will be eliminating the need to purchase the down-pipe fix > http://www.redline-motorworks.com/pr...ipe-fix-v3.htm
Does anyone know if the stage 2 software takes care of the dp fix? |
03-16-2011, 09:24 PM | #4 |
Rep 838
Oh snap! Mark at Pfaff told me the stage II flash comes with the fix. Unless he's talking about a newer fix or he could be simply mistaken. Perhaps Austin can chime in.
03-17-2011, 02:12 AM | #5 |
Rep 541
My stage 2 GIAC with the newest flash needs the downpipe fix ... I am using the Burger Tuning one. Have fun with the tune.
335 E92 - M-Tech - Eisenmann Race - Custom DP -RBturbos / Stage2 - GIAC S2 - Injen CAI - Forge FMIC - Forge DV's - Stri Gauges - ATI Pod - AEM Air/Fuel - Ericsson Carbon Trunk - Carbon Splitters - ER Charge Pipe - ER Engine Cover - Koni FSD - HR Sport - Brembo Racing Brakes - ICONZ custom rims - RPI Scoops - Burger O2 Sim
03-17-2011, 04:19 AM | #7 |
Rep 2,563
Confirmed.
They could do it, of course (in Europe almost all tuners offer this service if requested) but will not as tampering with emissions behaviour of a car is a criminal offense, IIRC. Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
03-17-2011, 04:24 AM | #8 |
Rep 513
Mark may be correct.....I have been running my stg 2 race flash now since march of 2010. I have had the burger v3 fix installed at the same time. I was running fully catless and got codes after running smoothly for 3-4 months. They were secondary cat codes and i could not get rid of them. I then changed my exhaust setup back to stock but with the catless dp's still in place and disabled the dp fix to try to get rid of some of the codes that terry said are hard to get rid of. As soon as the stock exhaust went back on the codes dissapeared, literally on the drive home from the shop. Now keep in mind i disabled the dp fix so it should have no effect on my cel.
Either way i am still running catless dp's with stock exhaust and no codes with the flash. So my car is an anomaly or giac did alter the software so it doesnt throw codes....highly unlikely. I tried asking terry on n54tech but got no response. This car is strange to say the least, but it runs without issue and when i scan with the bt no codes..... |
03-17-2011, 02:20 PM | #10 |
Rep 838
Thanks for the responses. Question: Does the dp fix tune out the CEL light completely or does it still provide a signal indicating there is an actual problem?
03-17-2011, 03:14 PM | #11 |
Mad Linux Guru On The Loose
1131
Rep 5,404
DP fix = CEL gone!
Been running it since April of last year!
03-17-2011, 05:28 PM | #13 |
Rep 838
Sorry, I wasn't clear in my earlier ask. I'm worried that the dp fix clears all CEL issues. If that's the case how would you know if you actually have a real problem???
03-17-2011, 06:21 PM | #14 |
Rep 513
03-17-2011, 08:27 PM | #15 |
Rep 3,177
all the downpipe fix does is manipulate the readings from the secondary oxygen sensors, so the dme "thinks" there are still cats in place. any other issues with the car will still trigger CEL's
03-18-2011, 10:43 PM | #17 |
1131
Rep 5,404
n54tuning.com is based off Canada, right? They carry all the BMS products and they should be able to get you a BMS downpipe fix.
