Quick help uninstalling my charge pipe please!! (With Pics)
03-20-2011, 03:50 PM | #1 |
Rep 369
So I am uninstalling my charge pipe (had it installed at a shop cause they offered to do it for free) and I just have two quick questions.
This vacuum line... Can I just pull it apart and re-attach to the stock parts or is there some sort of seal that I will break?? Do I just pop it off? And on the stock charge pipe there are these two smaller pipes coming off, one goes to each side of the air intake. Which one goes to which side? there is one at the front of the engine bay and one at the back... Please help me as I promised I would ship this charge pipe to the new buyer asap and he is waiting...
07 335i / Black on Red / Sport / Premium / 19'' Rims / Matte Black 18'' Winters / Vishnu / DCI / CF wrap / HID AE / OEM lip / H&R race / Titek / HKS |
03-20-2011, 04:07 PM | #2 |
442
Rep 18,331
Don't pull that apart but be gentle because the cloth end of the tube is connected to the intake manifold and if you crack the nipple off of the manifold you are screwed big time...Be gentle with that attachment.
03-20-2011, 04:15 PM | #3 |
3442
Rep 79,211
The end that attaches to the intake manifold is on a plastic nipple. If you tug and pull the wrong way it will break.
The vac line itself is like a chinese finger trap, the more you pull, the tighter it becomes. You need to push the line in, and grab the end and work its way off slowly. |
03-20-2011, 04:43 PM | #4 |
Rep 923
Here's a pic taken from the drivers side front quarter panel of how the stock charge pipe should look. The shorter of the 2 smaller pipes goes towards the front of the of the car as you can see in the pic.
03-20-2011, 04:43 PM | #5 |
Rep 369
Ok, Thanks guys... any tips on question two?
EDIT... THANKS JD!
03-20-2011, 05:01 PM | #6 |
442
Rep 18,331
I dont even bother even with those hoses...I am afraid to crack the nipple on the manifold so what I do is just cut off the hose thats attached and then razor the rest off to ensure of this...cutting off 3mm off the hose will not make it short for stock connection...This is 100% effective...Taking off those vac lines is a bitch regardless and even with jdbretz advice of pushing in, its still a bitch to get off sometimes!
03-20-2011, 05:21 PM | #7 | |
Rep 369
03-20-2011, 07:38 PM | #8 |
Rep 369
F((K!!!!! I am losing my frickin mind. For some reason I can't get the back part of the stock intake back together! It seems to be a bit warped and the outer part wont fit fit over the inner part.
Anyone have any tips on being able to fix this problem?? Pic: THIS IS ACTUALLY THE BEST I CAN GET IT... :S
03-20-2011, 07:47 PM | #9 |
Professional Moose Racer
316
Rep 7,509
Try heating the pipe up a little to make it more pliable.
Visit my blog anytime: http://www.sfpayments.com
BMW Dream Team PNW Chapter, member #1 |HP Autowerks | AR DESIGN | BMW PERFORMANCE | STOP TECH | Volk Racing| AMS | ARKYM |
03-20-2011, 07:50 PM | #10 |
Rep 369
not a bad idea actually!.. But sadly I'm a single guy without a blow dryer...
03-20-2011, 08:02 PM | #12 |
Rep 1,222
Push up from the Bottom pipe..that's the best way. You just have to grab the bottom accordion and push up onto the intake runner..don't try to push the intake into the hole.
03-20-2011, 08:37 PM | #13 |
Rep 369
Can't drive without the intake on... :S Might suck crap into my engine!
03-20-2011, 09:00 PM | #14 |
3442
Rep 79,211
All those aftermarket intakes combined with the heat cause the stock piping to shrink.
I got tired of it and went back to stock intake because of it actually. Use anything you can think of to safely stretch the pipe. |
03-20-2011, 11:35 PM | #15 |
Rep 369
Ya.. I see that now.. I'll try to get my hands on a hair dryer but other then that, I don't know...
03-27-2011, 09:10 PM | #16 |
Rep 369
One more question... and thanks so much to those that have helped so far.
Those two tubes that come off the charge pipe and go to the intake have small grey plastic rings on the ends that twist slightly to the right and left. I can't tell what the difference between right and left are. I assume one way is the "locked position" but does anyone know which way??
03-27-2011, 09:15 PM | #18 |
Rep 369
Thanks!!!
03-31-2011, 03:47 PM | #19 |
Rep 2,291
