stuck on 4000 rpm
03-21-2011, 02:03 AM | #1 |
Rep 1,284
stuck on 4000 rpm
Today ran a srt8 I smoked him 1st time badly, 2nd time I down shifted pretty late so when I floored it it was about 5600 rpm, when it switched gear it went up to 4000 rpm and stuck there for couple of seconds until it went into a limp mode , could that be my transmission is going bad or stuck throttle ?
03-21-2011, 02:47 AM | #2 | |
Rep 7,377
03-21-2011, 04:35 PM | #4 |
Rep 7,377
Did you read the codes?
03-21-2011, 05:01 PM | #6 |
Rep 1,179
lots of people will give you an unsolicited opinion, but few have enough technical depth to address a drivability issue --
i would heed the suggestions of some of the members like enrita -- as he has worked through problems very few see, or even want to experience. the lack of response may prove to be beneificial rather than negative -- cheers |
03-21-2011, 05:29 PM | #9 |
Rep 490
Drives: 335i
I agree, threads like this should be top priority. Op scan for codes so you can get help!!!
03-21-2011, 05:50 PM | #10 |
Custom Powder Coater
148
Rep 2,784
If this was with a JB3/4 you'd be blaming the tune already...Just STFU
03-21-2011, 06:00 PM | #13 | |
Rep 7,377
We also dont know which maps and settings OP was running.
03-21-2011, 06:13 PM | #15 |
Rep 1,948
03-21-2011, 06:19 PM | #16 |
148
Rep 2,784
Who was blaming the tune?
03-21-2011, 06:33 PM | #17 |
Rep 1,284
I'm running DIC 15psi no meth right now 100% IC , don't want to come outside right now to get the codes it's too nasty out lol , but the reason I've posted is because I thought that someone might've experienced the same thing.
03-21-2011, 06:35 PM | #18 |
Rep 7,377
octane? DTC completely off?
03-21-2011, 08:04 PM | #20 |
Rep 6,473
03-21-2011, 08:14 PM | #21 |
Rep 1,284
03-21-2011, 08:17 PM | #22 |
Rep 1,284
but it was holding 4000 rpm for liek good 2 3 seconds and didn't go up and then misfired it wouldn't go past 4000 rpms , it was like stuck there SO weird
