Factory 8"s not working after aftermarket sub/amp install?
03-21-2011, 11:38 PM | #1 |
Rep 459
07 335i E90 with L7
Hey all, I've been cursing the past 4 hours during my install. Couldn't find a damn remote trigger anywhere in the area, but I went ahead with the install any way. Here are my problems: Used a LOC and tapped in to the factory 8's under the seat. I noticed immediately after install that when music is playing, I'm getting no sound to my underseat subs. I unplugged the RCA's from my amp to ensure this. Also, when I have both (+) and (-) RCA's from the LOC plugged in to the amp, I get a totally screwed signal. When I just have one plugged in, it sounds about right. I definitely need to tune. Now I'm going to run outside to pull my remote wire, because I read on here that if I tap it to the factory amp power wire, it will turn off after 5 minutes, or 1 minute after locking the car. This isn't the case for me. So I'm ordering a low voltage remote trigger now. Any thoughts on the problems above? I've done all my installs on previous cars, and never stumbled on something like this. Thanks in advance! -Eric
Slammed 335i - Sold |
03-22-2011, 12:00 AM | #3 |
Rep 459
Meh, just ordered a PAC LOC and remote trigger, since I already have all of the needed wires t-tapped, I'll just wait for this to come in and go back through the install nice and slow. Should've waited in the first place.
03-22-2011, 12:05 AM | #4 |
Rep 7,089
Drives: '06 AW 330xi
The rem lead is pin 13 at the back of all oem HUs.
You probably tapped the wires incorrectly.....if the subs work after uninstalling everything, then it's your installation. |
03-22-2011, 12:07 AM | #5 |
Rep 459
I t-tapped:
SUB LEFT Red/White + Brown/Yellow - SUB RIGHT Red/Blue + Brown/White - As for the oem REM, I'd rather just use the remote trigger at this point, seems like too much hassle for one wire when I could just drop $20 and make it much, much easier.
03-22-2011, 07:31 AM | #6 |
Rep 3,969
You should have gotten Technic's harness...
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
01-14-2012, 12:44 PM | #10 |
Rep 3,201
02-16-2012, 07:48 PM | #11 | |
Rep 459
I can't really remember what the problem was, but it was on me, not the car. Now I'm tapped in to the cig lighter for my remote, and I haven't had a problem since.
