Warning: Make sure you check your meth injection setup regularly!!
03-22-2011, 02:09 PM | #1 |
Rep 5,876
I had no visible meth leaks in the past 1.5 years I've been running the setup except one at the wash fluid tank tap I made which I had to redo shortly after install (added silicone to secure it). I run my washer fluid tank as my meth tank, pump is behind the front bumper in front of the front subframe of the car and tubing goes up behind the firewall above the fan, where the filter+check valve+flow sensor are mounted, and then another tube goes down to the elbow before the charge pipe with a single M15 nozzle there...I dynoed with this setup while Shiv was here recently and I know it didn't leak back then as the hood was open and we would've seen it spray/leak, would've been dead obvious...
Right above the fan where I have the filter+checkvalve+flow sensor, I had reinstalled the plastic air scoop piece that delivers air to the DCIs about a year ago, covering the 3 key pieces in my meth setup and hiding them from easy view/access...yesterday, while looking around the front of the engine and examining an oil leak from the oil filter housing I took this plastic piece off to have a better look...i was shocked to see that the tube going from the flowsensor to the injector was OFFFFF I have no idea when it actually came off but the funny part is it came off AFTER the flow sensor...maybe it was a fluke and it came off suddenly while taking the plastic charge air piece but maybe not... What would've happened if I continued driving like this is basically a few potential disasters, plural..Procede would still end up get a max flow reading from the flow sensor, upping boost to map2 settings (flow at 50 would indicate an overflow to procede and it would drop a map but I'd maybe still be below that with my current settings and it wouldn't)...also, running 50/50 mix and considering it was still winter/cold here I was ok BUT had this been middle of summer with 100% meth at the track something could've gone really really wrong with high concentration meth "atomizing" conveniently into a hot engine bay.. I'm really glad I noticed this when I did...now, I have to say, I hate push fittings...I must change this to fittings that aren't of this type and which I can guarantee will stay in place 110% of the time...any suggestions how to retrofit something like that? |
03-22-2011, 02:15 PM | #2 |
Rep 461
I've had leaks from the push fittings (hose not cut straight) but never had a push fitting un-do itself. When properly inserted they are pretty tough to remove.
Maybe an install error? |
03-22-2011, 02:18 PM | #3 |
Rep 5,876
Maybe but the point is check "often" and don't run things outside the easy view otherwise human nature is to just ignore..sh*t goes sideways when you least expect lol
03-22-2011, 02:19 PM | #4 |
3442
Rep 79,211
This is why I upgraded to metal fittings...
Also... I dont think the failsafe would see adequate flow since there would technically be a boost leak in the entire system. Im having trouble thinking today so disregard that if it makes no sense lol. Anyway... Yea I went back to stock for a dealer visit. Put everything back together and I had 3 new leaks. So I upgraded everything. Everything was good for 2 years. I would say weekly checks wouldnt hurt. |
03-22-2011, 02:21 PM | #5 | |
Rep 5,876
03-22-2011, 02:41 PM | #6 |
Joint Chiefs of Staff
4927
Rep 116,037
Good catch! The JB4 assumes meth overflow at 2000ml/min and reverts back to non-meth settings. I'd be surprised if the PROcede didn't do the same. Still bad times having meth sprayed around in the engine bay.
Mike |
03-22-2011, 02:44 PM | #7 | |
1750
Rep 17,960
Drives: A Lot
Shiv |
03-22-2011, 02:49 PM | #8 |
Rep 5,876
I was getting overflow on the procede but I thought that was due to calibration on the cmgs...I'll relog later and confirm if overflow would've caught this if it really was off and spraying at any point in time...
03-22-2011, 02:50 PM | #9 |
Rep 1,495
Considering meth is basically fuel, I'm surprised there is ANYONE out there not using legit metal fuel lines and fittings for this stuff. I mean hell, better safe than sorry, right?
03-22-2011, 05:41 PM | #10 |
Rep 5,876
I just checked logs with the hose PLUGGED IN procede was dead on with overflow protection, if I'd only realized loose hose was a possibility procede was seeing flow between 43-55 and hitting overflow protection...now with the hose back in place it's back down to 17-23 with injection mode set to 14
03-22-2011, 05:55 PM | #12 |
3442
Rep 79,211
03-22-2011, 07:29 PM | #14 | |
Rep 3,012
03-22-2011, 07:30 PM | #15 | |
3442
Rep 79,211
Reason most people dont use AN fittings is cause of the cost. I do agree its a good idea. There are other companies out their that have AN fitting kits. |
03-22-2011, 07:36 PM | #16 | |
Rep 1,284
03-22-2011, 07:42 PM | #18 |
442
Rep 18,331
03-23-2011, 04:30 AM | #20 |
Rep 7,377
Dzenno think as well on those sub temps you got in canada. those hoses would get really hard and retract i suppose with cold temperatures. i have lots of slack on mine and i inspect them every now and than but yeah metal fitting would be better for peace of mind.
