how to clean valves at home
03-24-2011, 05:04 PM | #1 |
Rep 376
1. Have Engine At Running Temp
2. Take Intake And Charge Pipe Off 3. Start Engine 4. Have A Buddy Keep Engine At 1500 Or So Rpm's 5. Take A Can Of Amsoil Powerfoam Cleaner And Spray Entire Contents Into Throttle Body 6. Turn Engine Off And Let Sit For 10 - 15 Minutes 7. While Waiting Put Charge Pipe And Intake Back On 8. After 10 - 15 Minutes, Take Car And Drive The Hell Out Of It For A Couple Of Miles And Blow Alot Of White Smoke. 9. Now You Have A Smoother Running Engine Hope That Helps |
03-24-2011, 05:09 PM | #2 |
Mad Linux Guru On The Loose
1131
Rep 5,404
Do you have pictures of before and after?
...just asking because the official BMW tech procedure involves removing the intake manifold, rotating the engine by hand to expose intake valves one at a time, heating them up with a heat gun and cleaning them with a small brush (toothbrush) and BMW fuel injector cleaner....
03-24-2011, 05:53 PM | #6 |
1131
Rep 5,404
Sheep! Show me before and after pics of the intake valves! Until then, I still maintain that the smoke you see coming out of the exhaust during SeaFoam application is the seafoam itself being burnt and not the carbon buildup being removed...
03-24-2011, 06:02 PM | #7 | |
Rep 2,013
Seafoam does help get the top layer of it which is pretty good. |
03-24-2011, 06:05 PM | #8 |
Rep 1,551
These guys had some complaints about seafoam in higher mileage cars:
http://us.lexusownersclub.com/forums...howtopic=38852 |
03-24-2011, 06:09 PM | #9 | |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
03-24-2011, 06:52 PM | #11 | |
3442
Rep 79,211
Sometimes seafoam shows you the weakest links of your car, which may be a good or bad thing depending what your end goals are. |
03-24-2011, 07:33 PM | #15 |
Rep 3,175
I am not suggesting one product is any better than the other, but for those disbelievers you do realise that every gas company adds detergents to fuel in effort help keep the fuel delivery system, intake valves etc clean from carbon desposits to keep emissions down. As a matter of fact in addition to being mandated by the EPA, the EPA has conducted extensive testing of the effectivness of carbon removing detergents. That being said, the requirements the EPA set are a bare minimum requirement and no gasoline company with the exception of say Cheveron w/Techron (as far as I know) elects to exceed the minimum requirement - it's a cost issue.
Carbon is a byproduct of the combustion process, it's naturally occuring. To say there is a not a product available in any concentration that would remove any amount of carbon is a bit nieve and it flies in the face of the results demonstrated under controlled conditions in a labratory, as well as what I have witnessed. |
03-24-2011, 07:42 PM | #16 | |
Rep 1,495
03-24-2011, 07:48 PM | #17 |
Rep 461
03-24-2011, 07:52 PM | #18 | |
Rep 461
03-24-2011, 08:17 PM | #19 |
Rep 3,175
Look my point was do not discredit the effectivness of certain detergent additives. They have proven to be effective in a variety of engines both 2 stroke and 4 stroke.
03-24-2011, 08:23 PM | #20 |
Rep 3,175
Something tells me regardless of what I tell you, you still won't believe me. Let's just say I have torn down and rebuilt both 2 and 4 stroke engines, some were maintaned and others were not. It was readily apparent when someone wasn't using a decarb product.
03-24-2011, 08:49 PM | #21 |
Rep 461
Your right we won't unless you can prove it.
03-24-2011, 09:12 PM | #22 |
Rep 3,175
I have no interest in proving anything to anyone esp to some know it all kid. I have no vested interest in these products, I only speak from personal experience. Try lifting a wrench sometime, tearing down and working on an engine, experience I have found is life's best teacher. Otherwise, continue living in that blissful world of yours often referred to as ignorance.
