Does you auto transmission go “bang”?
09-29-2005, 04:56 PM | #1 |
C Kent
Rep 25
I need some help with a transmission question. Basically, I’m not sure if what I am hearing is normal or indicative of a transmission problem. Fist off, I have about 5500 miles on a 330i with an automatic transmission and have been hearing this for several weeks now.
The sound I am hearing is a sort of loose metallic slap or bang coming from the transmission and is louder and different than the normal muffled thump or bump that I hear most of the time. It happens about once a day in normal commuter driving. There is no mistaking the noise when it happens because it is fairly loud (about as loud as a person saying "bang" in a typical conversational voice) and much different than the usual transmission sounds. It is random and does not happen when shifting between 1, 2, 3, 4, etc. only when moving the shift lever between park, reverse, and drive. Nor does it seem to happen when moving from D to DS. So far I haven’t been able to find a particular situation that causes it to happen consistently so I have been hesitant to take it to the dealership (because I expect that there is only about a 50/50 chance that it will happen while the dealer has it). Other than this occasional odd noise the car seems to be running fine. Has anyone else heard this sound? Am I being paranoid? Is this normal in that sometimes the transmission just has some slack in it when changing from park, reverse or drive and needs to align itself? Thanks for any help. |
09-29-2005, 05:09 PM | #2 | |
Guest
Rep n/a
Drives:
05-17-2006, 04:26 AM | #4 |
Rep 81
Hey man. I got the same problem I have 13500 miles on my car. I think the problem from the way I drive (Sport Mode all the time).
What I did: Went to the dealer and they could not duplicate the problem. They ask me if it happens again to come back ASAP. On my way back home it's happen when I was parking. Next day drop of my car and they have an update for the transmission. Any way the update does not help to solve the problem and I’m going to them tomorrow. |
05-17-2006, 08:21 AM | #5 |
F=MA?
17
Rep 157
I've got the same problem on mine also with 9000 miles. I'm taking my car in on wedesday again and going to have them look at it.
Eldalo3-When you took it back were they able to duplicate the problem? What sorta update did they do? Just curious |
05-17-2006, 08:46 AM | #6 |
Rep 10,185
Transmission shouldnt make such a noise
Are you shure its not maybe a noise from the brakes taking up strain when you put it into drive? Say maybe you are not pressing the brake down hard enough or the handbrake isnt fully on and you shift to D, the engine tries to move the car and the brakes make a sound as they grip ??? Handbrake makes bang type a sound if you forgot it on and tried to mve off and then suddenly release it.
BMW if you are reading, I need a job, Please. |
05-17-2006, 11:07 AM | #7 |
Rep 130
I currently own a 545i, a phenomenon called "transmission slam" has long been reported in the E60 forums. It would happen most often from accelerating from a stop or incomplete stop.
The fix is a software update, at least for the 5 series. With the software update though, you tend to get new problems (the double-edge sword of updating your software). Not sure if that's what you have going on, but it does sound like a transmission software thing. |
05-17-2006, 05:26 PM | #9 |
Rep 139
Wow, transmission slam. Sounds nasty. How on earth would it be solved with software, I wonder. It's probably not the same, but on my old 325i manual gearbox, I get a big bang when the gear pops out into neutral from 1st. Scares the hell out of me when it does, and the passengers. I hope you don't have a similar serious mechanical problem with your transmission.
05-17-2006, 06:02 PM | #10 |
***** noob
1373
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
dawmm...this sucks
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
05-17-2006, 06:28 PM | #11 | |
Rep 6,874
Drives: 330i E90 C55 AMG
Garage List 2006 BMW 330i E90 [0.00]
2006 BMW 330i E90 [0.00] 2005 Mercedes Benz ... [0.00] 2002 Z3 2.2 USA Spo ... [0.00] 2002 Toyota MR-S Co ... [0.00] |
I am sure your foot should be pressuring on the brake pedal when shifting between in P , R , N . Try to step on it heavier see if any differences
BMW 2006 330i E90 Jet Black/Black Leathers/Aluminium, Steptronic Active Steering; MTech Aero Kit Carbon Fibre Splitters/Diffuser. Bilstein PSS9 Coilover, Rays VOLK Racing RE30 Formula Limited Edition 18" Pirelli Rosso; Project Mu 355mm Forged 4pot Caliper. HID:Osram D1S 6000K, PIAA 6500K White Ring, Philips Diamond Vision HB4 5000K, PIAA H490/H491 Super Bright 6500K LED Interior Lights. Chrome S.Wheel Cover, Rear Windows Sunshades.
05-18-2006, 06:06 AM | #12 |
Rep 12,276
With both my cars (mostly the E91, I've noticed) there is a metallic pop sound when the car is put into reverse from park. It is so consistent that I assume it is "normal". Perhaps it is the parking brake disengaging? The sound is very similar to a sudden expansion of metal, but no way the car has warmed up that quickly.
I think it is bad luck to be superstitious |
05-18-2006, 08:14 AM | #14 |
Rep 5,842
Drives: 2006 325xi
I am actually having somethign similar with my 6-speed. i just put on new 19 inch wheels and when i slow down fast i hear a thud, bang and it feels like the clutch isnt pushed in all the way. i dont think the lugs are loose but i have to check still... its strange.
05-18-2006, 02:14 PM | #15 |
Rep 2
I have not had this experience with this car, but I have seen something similar. If you park the car on an incline and put it in park with the brake on (normal way to do it), once you release the brake, the tension/load is taken up by the parking pin (or whatever it is called in the transmission). When you come back and take the car out of park, I have heard a "bang" as it lets go.
If you are parking on a hill, this may be related. You could also try to make sure you use the parking brake and that it is secure enough to not allow any movement when you put it in park or remove it from park. Rick.. |
05-18-2006, 03:06 PM | #16 |
Rep 106
Make sure your pressing hard enough on the brake. I had this problem and then I realized I wasn't pressing the brake hard enough and the problem was solved...hasn't happened since.
05-18-2006, 03:11 PM | #17 |
I'm Starving , So I Guess You Are What You Eat
235
Rep 943
my tranny make this noise also. its mostly when i start the car, and put it from park into reverse. but i believe its also happened when i stopped driving and went from drive to park. My old car (acura tl-s) did this also. But the type s tranny was NOTORIOUS for breaking. So i figured it was normal in that car, and now im worried that this car has the same symptons as a tranny that was none to break.
2006 325i Sparkling Graphite Metallic-Black Leatherette
Navigation-Bmw Assist Automatic-Xenons Carbon Fiber Front Lips-Aluminum Pedals Power/heated Front Seats 5% Tint all around 30% On windshield all the way down |
05-18-2006, 06:00 PM | #18 |
Rep 235
you would be suprised what a updated software could fix..
as for your problem i would worry about it.. the reason you dont hear it from d to ds is you are just telling you egs module(trans) that you want to hold the gear longer and have more agressive shifting |
05-18-2006, 08:44 PM | #19 |
Rep 106
So when I pulled into the garage today it happened putting the car into park, and I had the brake pressed pretty firmly. So...I don't know what the problem is, but it definitely doesn't sound normal.
05-18-2006, 11:34 PM | #20 |
235
Rep 943
i double checked my noise to. and there is deifnitly SOMETHING. when i put it into reverse, you hear the tranny shift, but it doesnt sound bad, or abnormal. THENNN one second later, after its already in gear, it makes a slightly louder, less healthy sounding noise.
05-29-2006, 06:33 PM | #22 |
Client Advisor
Rep 51
Could possibly be the rear diff mount. there was another one in our shop with the same problem. noise coming from car when coming to a stop or putting into gear. tech found that the diff mount was loose.
