Launch control with jb4
03-28-2011, 05:54 AM | #1 |
Rep 185
How do I engauge with my jb4?? There Is a launch control correct??
Planning on going to the track Saturday so I'm thinking about trying it out.. |
03-28-2011, 06:47 AM | #2 |
Legit :)
17
Rep 369
No, there's no such feature in the jb4
03-28-2011, 07:27 AM | #3 | |
Rep 731
Good luck at the track! -Travis |
03-28-2011, 08:16 AM | #5 |
ElevenPointFive
327
Rep 2,450
The JB3 did have a 'launch control' feature, is was basically a % boost reducer that you could configure. Not sure if this feature survived in the JB4. Post on the other forums about it.
2008 E90 335xi - N54 Daily Driver
MHD Stage 2+ ~ CPE DPs ~ BMS Intake ~ AMS FMIC |
03-28-2011, 11:44 AM | #7 |
Rep 185
Damn, oh well I'll launch the crap out of it in 2nd..I'll let everyone know what it does...track will actually be WEDNESDAY..hoping for 12.7 @ 110
03-28-2011, 12:36 PM | #8 |
Jerry's Fault...
175
Rep 9,258
What other mods do u have???
Boopie*Motorwerks Martino*Auto*Concepts |
03-28-2011, 01:00 PM | #9 |
Professional Moose Racer
316
Rep 7,509
Not even close, man.
Visit my blog anytime: http://www.sfpayments.com
BMW Dream Team PNW Chapter, member #1 |HP Autowerks | AR DESIGN | BMW PERFORMANCE | STOP TECH | Volk Racing| AMS | ARKYM |
03-28-2011, 02:37 PM | #10 |
Rep 461
If you find traction problems too severe in 1st and/or 2nd gear you can cap the maximum boost/torque achieved in those gears to aid with traction. You'll find them under user settings. A value of 10.0 in 1st and 12.0 in 2nd will limit boost to 10.0psi while in 1st gear and 12.0psi while in 2nd gear. When in 1st or 2nd gear under the boost limit you may hold down the steering wheel volume or talk button to bypass the limit while the button is held down. For example if doing a burn out at the track.
03-28-2011, 03:45 PM | #11 |
Rep 2,875
That's not launch control IMO.....that's just basically a reduction of boost in lower gears to get 'better' traction.
Launch control is when you're able to hold the rpm and build full boost before launching, not a reduction, no? You'd probably be better off using your right foot as 'launch control' if you're running JB.
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
03-28-2011, 06:29 PM | #12 | |
ElevenPointFive
327
Rep 2,450
If you are running an auto tranny, get a set of DRs and you wont have to worry. Brake boost to 2300 rpms and you can mash the gas off the line with DRs set at 20psi and properly warmed up. Shift at 6200 rpms for optimal performance down the track.
03-28-2011, 08:33 PM | #13 |
Joint Chiefs of Staff
4927
Rep 116,037
The JB4 has traction assist and a drag launch mode. The drag launch mode is for those running full slicks trying to leave the line under high boost values. I think they've only told a few people how to enable it pending more track testing. The traction assist on the other hand has been used by many and is easy to setup.
Mike |
03-28-2011, 08:36 PM | #14 | |
Jerry's Fault...
175
Rep 9,258
04-02-2011, 04:18 AM | #16 |
Rep 469
Drives: BMW 16' M3
Lol....your a XI. Just brake boost to about 2500 rpms and should be fine.
04-02-2011, 07:21 AM | #17 |
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
....and turn off the DTC. ^^^
04-02-2011, 08:13 AM | #18 |
Rep 1,546
Ive played with the launch boost reduction using first gear at MAX 10psi and 2nd+ @ full boost.
It def helps as at 10psi i was getting very minimal wheelspin, so i tryed it at 11 and thats where it felt perfect. IMHO, this is even better than launch control, reudcing boost. I am able to brake boost and still luanhc my car hard, i might even leave first gear boost at stock levels and brake boost and launch as hard as i can out the hole with the stock first gear boost. |
04-02-2011, 09:02 AM | #19 | |
Rep 1,284
04-03-2011, 02:23 AM | #20 |
Rep 858
