Review & Dyno - GIAC Stage 2 with "tweaked" maps, different downpipes, fully catles
03-28-2011, 08:01 AM | #1 |
Rep 1,809
So I needed to reflash my GIAC S2 maps because the dealer has erased my flash. But since I have noticed some timing pull in the logs earlier (also reported by others), I asked GIAC if something could be done about it. Our fuel is of low quality and I asked GIAC if I could have a flash which works well with 95RON (91 US) fuel. Tom @ eas told me that GIAC "tweaked" my maps such that it would work with 95RON with no timing pull.
In the mean time, I have also replaced my OEM catless downpipes with 3" Macht Schnell coated downpipes (quality and fitment is great, btw) and I have replaced my secondary cats with Vibrant 1792 resonators (made a world of a difference). From the logs I gathered until now, there is no timing pull whatsoever. I noticed that in 3rd and 4th gear, the timing starts about 2 degrees lower than before, but ramps up to the same 11 degrees at the top. The new maps are annoyingly smooth Smoother than before. 2nd gear definitely pulls harder, 3rd gear seems to pull lower in the midrange and 4rd gear seems to pull the same or harder. Today I have dynoed my car and I got 3whp lower power despite the fact that I have removed the secondary cats and I installed larger downpipes. 331whp vs. 334whp (Mustang dyno, corrected values). However, at higher RPMs the car pulls noticeably harder, and it shows on the graph (the graph is below). By the way, I highly recommend EAS if you need to send your ECU for GIAC reflashing. They are located very close to GIAC headquarters and they communicate very closely. They are also very responsive to PMs, etc. Couldn't ask for better. Last edited by tscdennab; 03-28-2011 at 10:17 AM.. |
03-28-2011, 09:59 AM | #3 |
Rep 1,809
03-28-2011, 10:08 AM | #4 |
Rep 2,563
Looks very good!
I still have an issue with the race map but hope to get that sorted during the spring. But the S2 flash is very very good and a pleasure to drive. Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
03-28-2011, 10:16 AM | #5 |
Rep 1,809
What issue do you have with the Race map, if you don't mind ? I didn't switch to the race map until now because I'm struggling to install my meth kit.
03-28-2011, 10:30 AM | #6 | |
Rep 2,563
I hope to be able to troubleshoot that in the next few weeks! Alpina_B3_Lux
03-28-2011, 03:25 PM | #7 |
Rep 1,495
Just out of curiosity, why don't your torque and power intersect at 5280rpm's??? Is it because of the units used to measure the output not being lb•ft and hp???
03-28-2011, 03:57 PM | #8 | |
Rep 1,051
Lance |
04-02-2011, 10:36 PM | #9 |
Rep 1,410
So, with GIAC stage 2 you still need O2 sims correct? I am looking to get this with some catless DP's, probably MS coated. I will be ordering this week and just finishing up my research. I already have the MS stage 1 intake and AMS FMIC... and just ordered the Synapse BOV kit.
Cheers |
04-03-2011, 03:31 AM | #11 |
Rep 1,809
04-06-2011, 08:56 PM | #12 |
Rep 2,626
Looks good man
Did you ever do a baseline run?
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
04-07-2011, 02:53 PM | #14 | |
Rep 372
