Procede going into valet mode on dyno?
03-28-2011, 01:33 PM | #1 |
Rep 1,343
Drives: BMW M3 DCT
Shiv any news on how to fix this problem with the procede going into valet mode on the dyno?
Or if anyone else can help me at that...? |
03-28-2011, 04:36 PM | #2 | |
1750
Rep 17,960
Drives: A Lot
It also helps to turn off autotuning just prior to running on the dyno. Because each successful pull on the dyno will make the car detune due to typically poor dyno conditions (weak fan, no airflow, etc,.) I really do have a more in-depth write up coming but just trying to find the time to finish it. |
03-28-2011, 04:42 PM | #3 |
Rep 611
Yea he is referring to first having the car in manual mode so you can control the shift, and second making sure that the operater does not push the pedal past the kickdown...in the DCT or the AT if you push the pedal past the kickdown it automatically downshifts to the optimum gear for max acceleration.
03-28-2011, 06:54 PM | #4 |
Rep 1,343
Drives: BMW M3 DCT
Sorry i am kind of new to the procede software.
I am in the menu right now; |
03-28-2011, 07:12 PM | #6 |
Rep 1,343
Drives: BMW M3 DCT
okay, then how would i be able to run 15 stable instead of it auto tuning down or going up to 16 or 17 etc?
03-28-2011, 07:16 PM | #8 |
3442
Rep 79,211
If you want it to only run 15...then just set it to 15 with no autotune.
However, I would set it to 14... with a maximum of 16 and let autotune do its thing. Those turbo's have trouble breathing up top anyway. So I wouldnt push it. I would let autotune do its thing. |
03-29-2011, 10:00 PM | #9 |
Rep 1,343
Drives: BMW M3 DCT
So the auto tune will only come into play with boost only correct? Not with timing and other things the procede is doing right?
So i can turn off autotune if i want 15 psi only. |
