Possible Vacuum Leak?
04-11-2011, 10:57 AM | #1 |
Mad Linux Guru On The Loose
1131
Rep 5,404
Hi Folks,
I've done some logging with the COBB AP recently and I noticed that at idle, the engine barely makes 0.5 psi of vacuum. Normally it sits at 0.0 or 0.01 vacuum. Is this normal for the N54? ...or do I have a vacuum leak somewhere? If I indeed have a vacuum leak, my guess would be its because of the BSH occ, as I have no other engine mods that could affect the vacuum. Thanks for your time.
04-11-2011, 11:25 AM | #2 |
Rep 2,558
Uhhh... my boost gauge (and others I've seen) have anywhere from -18 to -21 vacuum at idle... although now that I think about it, -21psi is a LOT and so I'm not really sure what that means... but I've never sat at 0 before...
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
04-11-2011, 11:44 AM | #4 |
Rep 5,040
same, -21 at start and settles to -18 after warm up
04-11-2011, 12:34 PM | #5 |
1131
Rep 5,404
WOW! -18 to -21 at idle! Now I am worried!...
How are you guys measuring the vacuum? I am getting my results from the live engine monitoring from the COBB AP. At idle, I am showing -0.5psi and more often -0.1 psi of vacuum.
04-11-2011, 12:35 PM | #6 | |
Rep 2,875
Are you reading this off your boost gauge?
The ONLY time my gauge reads 0 is only when the car ignition is 'on', engine off......so there's no way that it can read vacuum without the engine running? As others have said, the vacuum readings should be in the negatives......mine read -17 vacuum. Quote:
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
04-11-2011, 12:37 PM | #7 |
1131
Rep 5,404
No boost gauge yet as I am waiting for the P3 v2 gauge since December of last year. I am using the Cobb AP live monitoring to measure boost.
04-11-2011, 12:48 PM | #8 |
Rep 5,040
04-11-2011, 03:22 PM | #9 |
Rep 2,875
So that vacuum reading was with the engine 'on' ?
04-11-2011, 03:36 PM | #10 |
1131
Rep 5,404
Yes! Engine is on at idle...
04-11-2011, 03:39 PM | #11 | |
1131
Rep 5,404
Can someone with a Cobb AP do me a favor: start your car and let it idle? Then tell me what is your boost/vacuum at idle as seen by your Cobb AP unit. Thanks in advance.
04-11-2011, 03:45 PM | #12 |
Rep 6,631
When I had the 135 with mechanical boost gauge, my vacuum read -19 to -21 as well. I think the Cobb reads pre boost; you're fine.
E90 LCI N54 6AT
04-11-2011, 03:54 PM | #13 |
Rep 1,708
you're only seeing map before the throttle, so your lowest reading is baro. Cobb probably takes out standard, average baro in the logging calculation.
04-11-2011, 04:09 PM | #14 |
Rep 1,262
Make sure you consider units when reading off a gauge. What most of you are seeing is ~18 In of mercury (at 32*F) Which comes out to about 8.5 PSI if I'm not mistaken.
The pressure sensor the COBB is reading sits upstream of the TB, and on idle this sensor will not read the actual manifold pressure, since the TB is closed. People with boost gauges read off the line from the DV's, which goes to the manifold, readign the true vacuum pressure.
Josh-
04-11-2011, 04:10 PM | #15 | |
Rep 2,626
So I'm sure I read somewhere that it is normal for us not to see negative boost readings with the CObb ap (has to do with how the COBB fetches those values vs a regular boost gauge). So don't worry about negative values. On the other side, I can let my car idle and check the idle boost for you on COBB AP, after work .
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
04-11-2011, 04:19 PM | #16 |
1131
Rep 5,404
Good info guys! Thanks for the clarification. It makes sense. I also watched a demo video of the P3 gauge (v2). It also reads from the CAN bus and it shows almost no vacuum.
04-11-2011, 07:19 PM | #17 | |
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
I normally read about -20 inHg on my P3 gauge. That "PSI" light is misleading. |
04-11-2011, 08:09 PM | #18 |
Rep 840
Just to clarify and confirm what a few others already said, the vacuum reading that the P3 gauge shows is in In.Hg but the boost reading is in PSI. To convert In.Hg to PSI, you need to multiply it by 0.4912.
Cobb reads shows the data from the engine's boost sensor that is before the throttle blade and I don't think there is any vacuum in there. Correct me if I'm wrong. |
04-12-2011, 12:49 AM | #19 | |
Rep 2,626
So I hooked my AP today. I was reading 0.1 PSI when the car is idle.
04-12-2011, 04:05 PM | #20 |
1131
Rep 5,404
Thanks. This makes sense! I appreciate it.
10-14-2013, 09:03 AM | #22 |
Rep 488
Drives: 2008 335xi E90
Sorry to revive old thread. Can the Cobb AP read actual vacuum in the engine. Any sensor in there, or do I need to hook up a vacuum gauge like how the P3 is connected? Thanks.
MHD Self-Tuned Scaled FlexFuel Map | M-Boost | N20 Tmap | Helix IC | Fuel-It Stage 2 LPFP | BMS DCI | BMS Thermostat Delete | CP-E Charge Pipe | Tial-Q BOV | Apex Arc-8 Hyper Silver | Michelin PSS | Cool Carbon Brake Pads R/T | SS Brakelines | ECS 2-Piece Rotors F/R | xHP Stage 3 | xDelete Sport | KW-V1 Coilovers | Turner Strut Brace | Lux Angel Eyes | CF Kidneys | Scoops
