Snow Foaming
04-13-2011, 03:22 AM | #1 |
Rep 3,608
Snow Foaming
I've had my Karcher for over 2 years now, Its been good and very reliable when I bought it it came with a few accessories like the T200 patio cleaner and the Snow Foam lance, I use the patio cleaner but have never try using snow foam lance I might try snow foaming the car this weekend, firstly I have no clue how to snow foam a car and also need some good snow foamer fluid.
Can someone help me and tell me a good snow foaming method and some good snow foam liquid ,Thanks |
04-13-2011, 03:54 AM | #2 |
Rep 2,834
04-13-2011, 04:47 AM | #3 |
Rep 6,949
The foam lance that comes with the Karcher machines isn't all that good, better to have a dedicated snow foam lance. Having said that it will produce some results but playing around with the amount of concentrate and water is essential.
04-13-2011, 05:28 AM | #4 |
Rep 4,302
A lot of PWs come with a soap applicator that looks like a snow foam lance but isn't.
I use the Autobrite heavy duty lance and their Supafoam - both work a treat. Did the Landy yesterday - this is a fairly decent thickness of foam: And it ended up like this: |
04-13-2011, 05:43 AM | #6 |
Rep 4,302
It sees many fields, beaches, picks up logs, builders stuff, tows boats, hauled a clients A3 out of a ditch and rather handily, two surfboards fit inside!
04-13-2011, 05:48 AM | #7 | |
Rep 3,608
Do you use the snow foam lance in toxicnerves post? |
04-13-2011, 05:53 AM | #8 |
Rep 4,302
Nope - I use this one:
http://shop.autobritedirect.co.uk/fo...ions-305-p.asp and this foam (I bought 5 litres) http://shop.autobritedirect.co.uk/su...izes-346-p.asp I think the PW you use can make a difference - Nilfisk E140 in my case. |
04-13-2011, 06:02 AM | #9 |
Rep 1,733
I have the Autobrite Heavy Duty Foam Lance for Karcher. Has only got stuck once, but a wee clean out and all good.
Also the Autobrite Snow Foams (one with wax) also have Meguires stuff but much of a muchness. |
04-13-2011, 06:25 AM | #10 | |
Rep 2,834
04-13-2011, 06:28 AM | #11 |
Rep 824
Drives: BMW 530e G30
Does it have to be warm/hot water? ive always just used cold water cos the water connected to the pw is cold anyway so would it make a difference?
BMW 530e G30
04-13-2011, 06:36 AM | #12 | |
Rep 2,834
I can only guess that the foaming-agents are "activated" by warmer water before being mixed into the cold flow of the PW??? |
04-13-2011, 06:38 AM | #13 |
Rep 824
hmm.. maybe so. might give it a try with hot water and see if there is a difference.
Also the Bilt Hamber foam is good for cleaning, not so good for producing foam but cleans well
BMW 530e G30
04-13-2011, 07:20 AM | #14 |
Rep 4,302
+1 - tried both and warm/hot water definitely makes it foam better. Also no idea why!
04-13-2011, 07:38 AM | #15 |
Rep 2,472
Wee tip for you. *Go to that site where OCD people talk about washing cars (it rhymes with bee tailing knurled) join up and take advantage of the members discount that Autobrite offer on their HD foam lance with connector for your washer and a small bottle of super snow foam for under £40.
I use the Autobrite HD foam lance and have recently stated using their magifoam. I find it very good but have never used anything else apart from the super snow foam which was still good but not as good. * Hopefully not breaking any rules here.
Daily Golf R
Project Peugeot 205 1.6 GTi |
04-13-2011, 07:47 AM | #17 |
Rep 2,472
I believe that if you have one of the higher end pressure washers, do it often enough and get the mix right then you can actually enjoy bucket free washing. At least that's what the experts have led me to believe.
Daily Golf R
04-13-2011, 08:33 AM | #18 |
Rep 4,302
TBH you still need a quick wipe with a mitt - proper grime doesn't quite lift off. It takes the bulk of the grit/dirt off so you don't produce swirl marks with your sponge/mitt and has magic stuff in it that attracts fairies, pixies and elves.
04-13-2011, 10:32 AM | #20 |
Rep 6,949
Autobrite lance is excellent, once you get the quantities right it produces great fluffy foam. As said above you do need a wipe over with a wash mitt but all the worst of the grime is easily washed away.
04-13-2011, 11:00 AM | #21 |
Rep 348
Another Autobrite foam lance user here. Mines clogged up once in 2 years. They sell spare gauzes and I'm about to replace it. Other than that, faultless.
I use bilthamber autofoam though.
2007 320D M Sport Touring Sparkling Graphite
04-13-2011, 01:13 PM | #22 |
Rep 1,113
Drives: M235i 6MT
Another autobrite foam lance user here. I use the bilt hamber foam also.
I've never found it actually removes much dirt, but rather loosens it so that the regular wash with the mitt is easier. Maybe I'm doing it wrong. I also find I get better results with hot water in the lance bottle! |
