Help! which replacement droplinks after coilovers (e92)
05-03-2011, 01:17 PM | #1 |
Rep 825
Hi people, as title, i know with e46's people use Hyundai rear drop links as replacements, but what to use with the e92 as the ones i got are shocking and knocking already.
thanks in advance jamie |
05-04-2011, 02:44 PM | #6 |
Zummerzet Zyder Drinker!
112
Rep 5,541
Drives: '06 330D Le Mans Blue
Just buy some replacement OE replacements!
05-04-2011, 04:00 PM | #7 |
LSD - No, you're not seeing things
72
Rep 3,302
If you have a really big drop then you may change the angle a little and lose some stiffness, 'tis true.
But the biggest reason for adjustable links would be to balance the bar after a corner weighting / ride height session. Sometimes you get a little uneven loading which you can dial out. You should find oem length is fine. I have never heard of anyone needing to alter them for example. I bought some new turret tops from here in Denmark this month, came in a week: http://www.schmiedmann.com/ Good prices on pattern parts and the quality was absolutley oem. Steve
05-05-2011, 06:16 AM | #8 |
Rep 825
The OE droplinks are 300mm and the ones with the kit (i measured last night are 240mm) so i bought some Lemforder ones from a Ford Puma (238mm) and they are an ideal replacement for anyone thinking of lowering in future,
thanks m1bjr for your help , appreciated. Last edited by Jamie_E92; 05-05-2011 at 02:21 PM.. |
